GLK 350 Offroad Wheel/Tire Setup
https://mbworld.org/forums/glk-class...-question.html
Here’s a basic help guide on doing the lift.
https://mbworld.org/forums/glk-class...tallation.html
https://rdbase.jp/18482/
They are 17's 245/65 Can zoom in on the pic and see for sure.
Now, what I really want to know is, what model rim is that?
I love the round hole style for an off-road look.
99% of rims are spoked style and just don't cover the rotor enough for my taste.
I even contemplated steel rims like spare tires use because I think they look better.
Not into the pavement princess look.
I don't hate these, and they won't break the bank.
MOTEGI MR141
17x7.5 5x112 ET40 with 66.6CB fitment
Only a 40mm offset, and I'd like to push the tires out far as possible, but hard to find a 17x7.5 5x112 +35
So much, so I ponder if that one rdbase did is running 7" wide rims, but I'm not sure if that would cause a problem.
That half inch really cuts down on options.
Maybe that one is lifted if the 245's it has on don't rub.
Could get it lifted new struts rims and tires for just over 2k
18x8 5x112 +35
Will they fit?
I know MB says 8.5 for anything over 17", but less shouldn't interfere, right?
Feel like they'd wear a pair of 235/60s with an even fatter bulge and look sweet.
I bought the strut set and lift fit, just about finding wheels now.
Sorry if I'm thread jacking, I just figure better to keep it in one thread like this.
EDIT: How important is hub bore? They're 73.1 not 66.6...
That means the 8" wheels with +35mm offset will move the INSIDE of the wheel out a little further. The offset moves the wheel out 10mm, but being 12.7mm narrower the outside lip of the rim should be very close to the stock rim placement (actually 2.7mm further in).
FWIW, I believe most of the newer GLA/B/C/E wheels have more positive offset (moving the wheel IN from the fender lip, requiring a spacer in many cases, including mine).
I am looking at getting 17x8.5. I dont see an option for an 8.5 width 17 inch wheel. There is an option for a 19 and 20 inch wheel at an 8.5 but not a 17. Whats the downside to using a 17x8.5 and any thoughts on what the offset needs to be?
Mercedes Wheel Spec
https://www.wheel-size.com/size/merc...m-glk-350--302
