Chain slap persists, startup rattle
If I'm right thus far then it seems to me like the check valves don't actually do much.
The chain doesn't feel like it has any extra slack, and the tensioners eventually do their job.
What's the solution here?
Here the "noise" even after tensioners and adjusters...
https://youtube.com/shorts/pi15y04Xcro?feature=share3
..and then it's gone and everything's fine after 2-5 seconds.
Which in my understanding is caused by the upper timing chain tensioners losing oil, while sitting. The whole MB startup rattle bulletin that effects a lot of their engines.
It was my understanding the check valve was supposed to fix this.
The adjusters I removed we're worn at the pin. There are YouTube videos dissecting the cams showing the exact damage that I found, but still that noise.
When I first bought it, 2k miles ago, the startup rattle was bad enough with the worn cam adjusters to cause the startup to sputter, blub blub blub. It's a strong start now as you can hear, no sputter for seconds like with the old bank 2 adjusted. Overall it's "better", but...
Since doing bank 1 adjusters though, no improvement. In fact I've got a CPS code now I didn't before. We'll see if that clears.. I think it's pretty clear to hear that's not an adjuster anymore if the idol is right. That sounds like chain slap to me, until the tensioner gets pressure.
The tech I called was talkative and he actually told me maybe it was the lower timing chain tensioner. I haven't looked into that yet. I might just throw some money at someone to do it. Still getting over making things a lil worse lol
I've read so many threads about this. Watched every video and read ever comment. Some get rid of it with a mystery oil, or a thicker oil, a thinner oil, a seafoam cleaning. Some folks fake the car out three times before starting it.
I'm starting to wonder if the oil starvation isn't due to build up. While it looks clean in the engine they intake valves are gunky.
If it was a lifter it would be continuous not just at startup right? It's gotta be oil starvation to the tensioners, and the check valves don't do much.
Many oil companies use the "meets or exceeds" language without actually obtaining the specific manufacturer approval/license. Perhaps do a few short oil change intervals with the proper MB 229.5 spec stuff and see if the noise and cleanliness improves.
Have you checked the chain for wear?
edit:
I don't even get the point of a hydraulic tensioner. Why not a spring that does the heavy lifting.
I don't have the ***** to try to remove them. Lol, and
from what I've read other experienced, I'm not sure a second set would fit tight.
Valve train would be continuous. Not for two to five seconds exactly like the startup rattle that's so common, and often unresolved.
I've pinpointed the issue to the hydraulic tensioners. Nothing else makes sense.
So I wonder how much pressure those hydrologic tensioners are getting at idle, and if a spring inside could do some of the heavy lifting at startup. They're the fail point for all this startup rattle timing chain slap, possibly stretch, and definitely adjuster wear, Which can even lead to cam replacement if the pressed on plates spin any.
Although I read a thread where a guy turned them back into perfect timing with a crowbar through the CPS hole and a hold on the crank.
I honestly think thinker oil makes more sense. It's better protection and the added time it takes to reach parts is going to be milliseconds, and this rattled is for 2-5 seconds.
There aren't forum posts from 2013 about this rattle, it took a few years, 60- 80,000 miles to start popping up for people. To me that says carbon build up.
I wonder about Carbon X K1 and K2. Normally I wouldn't buy into that crap because it doesn't stay long enough to really clean, but this stuff requires a neutralizer and I believe a flush of oil? Not sure. Not sold in the US.
The noise is hard to tell, almost sounds plastic on plastic. Like if you had a fan hitting shroud (I know it's not). Did you take the belt off to check all accessories? Also look at them at the start-up?
Did you check vacume to test the PVC with a vacume gauge? To get an idea if there is an issue remove oil cap while motor is running and notice the amount of suction pulling on the oil filler cap. Lift it and put it down several times. There should be almost no pull.
It is caused by a known issue where the pvc doesn’t seal anymore to the valve cover because the gasket is bad. Excessive vacume sucks oil DOWN from the top end. PVC go bad at 70,000. Well mine went bad! You keep going to the chain, there are many more things you’re ignoring and dismissing . Havnt you replaced all the parts on the chain that could cause this ? But you continue with it.
