Transmission is I n park, but it it says it’s not like the door is open ?
Old Sep 29, 2023 | 03:56 PM
spitfire3/87's Avatar
glk350 rwd
Went out yesterday for lunch and a carwash , returned to work and parked car like normal . When I got in it several hours later to go home the engine started up just fine , but I went to put in gear and nothing . The dash indicator shows it’s parked . Buy it’s giving the roll away message that it does when you open the door while engaged in any gear other than park .
i have pulled the sam, checked all fuses . Made sure the car was getting signal from the column gear selector . Still nothing .
how do I tell it it’s not out of park ?
Old Sep 29, 2023 | 03:58 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Did you wash under the hood? If so, some sensor(s) might have gotten wet, and might dry out and return to normal operation...
Old Sep 29, 2023 | 06:49 PM
glk350 rwd
There was definitely water under the hood that poured over the cowl due to clogged drains . But I have used a heat gun, set in sun for a day , still nothing . In the past that has worked , this time it isn’t . If I could just get a pin out of the SAM plugs to locate what wire is sending the signal I think I could get it going .
but it’s hard enough finding fuse and relay info , let alone a pin out of the plugs underneath .
Old Sep 29, 2023 | 07:50 PM
Mmr1's Avatar
2013 glk 350
Maybe let the motor idle and run 15 minutes to get warm , and try it 6-24 hours later. It will get hot in the engine compartment and dry everything
