Radiator Leaking
Old Oct 26, 2023 | 01:24 PM
andreigbs's Avatar
GLK 250
I would start the engine, set heater to max heat and fan blower to max, let the engine warm up and send coolant into heater core to burp it. Make sure coolant cap is sealed and DON'T open it up once it reaches temp to top off. You'd rather add a bit more coolant now or let it cool then top it off. You may have to do this a couple times.
Old Oct 26, 2023 | 02:53 PM
Dhollenback's Avatar
E320 W211
Thanks. So, do not leave cap off to burp it? I hope to burp it when I get home tonight.
Old Oct 26, 2023 | 03:02 PM
andreigbs's Avatar
GLK 250
No, because the system will not be pressurized. You can burp it more when you take the cap off to top off the coolant, the next day or when it cools sufficiently. What you want is to get coolant into the heater core thus displacing the air.
Never run the engine with the coolant cap off or it will puke out coolant from that expansion tank as soon as it warms up a little.
