Help - Custom Tail Lights on '10 GLK
Old Nov 7, 2023 | 04:32 PM
rsn_x204's Avatar
2010 GLK 350
Hi!
I recently purchased custom tail lights on Aliexpress for my 2010 GLK. They arrived today.
I have an issue. The brake lights function as the turn signal, while the turn signal functions as the brake light (see attached video). Clearly, it is supposed to be the other way around. A resistor was included and was plugged in during the test.
I did see a thread about retrofitting facelift tail lights on a pre-facelift that involved repinning of wires. Could that be necessary in this case?
I do not know if anyone might have a solution, but any help is appreciated.
File Type: mov
Old Nov 7, 2023 | 05:23 PM
angryartichoke's Avatar
2011 GLK 550
If your brake lights are functioning as the turn signal, and your turn signal is functioning as the brake light it's safe to assume you need to swap those around in the harness.
Very easy to do with a SIM card removal tool.
Old Nov 8, 2023 | 11:23 AM
habbyguy's Avatar
2011 GLK 350 4Matic
Off-topic, but I just have to ask... angryartichoke, is your vehicle a GLK 350, or a GL300, or a model I've never heard of (but would like to!), or maybe it's got a transplanted GL engine? ;-)
Or was that a typo?
Never mind - just saw another post in which you said "I M273 swapped mine". Answers THAT question, though per 'net rules, "if there ain't pictures, it didn't happen". ;-)
Old Nov 8, 2023 | 12:25 PM
rsn_x204's Avatar
2010 GLK 350
Do you by any chance have a video on how to swap those wires around? I do have a SIM ejector tool around, but I am scared to mess anything up.
Old Nov 8, 2023 | 01:51 PM
MBKLUE's Avatar
Yikes:
Originally Posted by rsn_x204
Hi!
Is it possible you bought the taillight setup for Europe or other parts of the world? For most markets there are dedicated amber turn signals at the rear. The U.S. and Canada have an odd fixation with keeping the brake lights and turn signals, on most cars, the same color - red. Just a complete lack of common sense.
Old Nov 8, 2023 | 02:07 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Might consider asking a friend who's versed in wiring or has confidence in the general procedure.
Old Nov 14, 2023 | 12:22 PM
rsn_x204's Avatar
2010 GLK 350
The 2010 - 2012 GLKs w/o the lighting package have amber rear turn signals.
Old Nov 14, 2023 | 12:23 PM
rsn_x204's Avatar
2010 GLK 350
I have done some messing around on my own, and I have discovered that I am, in fact, required to swap the brake and signal wires around in the harness. It takes a little bit of patience, but it is not *so* hard to do, thankfully.
