2015 GLK 350 Odd Transmission Behavior
Hi guys. I am fairly new to the MB gang. I purchased my first beauty, a 2015 GLK 350, a few months ago. This car is awesome. Like freakin awesome. However…
I’d say about a month ago, I started to notice some odd shifting behaviors. This comes in 4 varieties…
1. The most noticeable. The upshift from 4-5 is terrible. I’m talking a jerk that everyone in the car can feel. It feels like I am getting thrown backward, then instantly forward. It almost feels like a momentary lapse in acceleration. Now I will say, it does not happen every time, maybe like 80%. It happens more noticeably in E mode, and it seems to happen more the longer I drive that trip, meaning the transmission is hotter. I have an iCarsoft, which I have used to reset the adaptations, which did help tremendously, but only for about a week, then the issue slowly returns. I am leaning towards software issue for this? Why would resetting the adaptations solve a hardware issue?
2. The downshift from 4-3 sometimes leads to a clunk. Not an audible clunk, but one that I could very easily imagine making a clunking noise. It’s a very different feeling that Problem 1 that I described above. There’s not the “momentary lapse in acceleration” like in the above, but honestly most a really clunky downshift. Resetting adaptations did not seem to fix much for this one, but they do a little.
3. This one is weird. The GLK has 2 shifting modes, S and E. This problem only happens in S mode. Normally, S mode shifts each gear at around 1800-2000 rpm. However, if I even remotely step on the gas, the car will go into this “aggressive mode”, where each gear starting at 3 will only upshift at exactly 2800 rpm. 1st and 2nd seem relatively uneffected, but 3 and 4 and 5 are terrible. I honestly cannot get out of these gears without using the paddle shifters. This “aggressive mode” does not turn off until the car is turned off. I’ve tried switching to manual mode and also E mode, to no avail. Also, this mode persists even after adaptation reset.
4. Finally, I am having some vibrations over about 70 MPH. This one could be a drivetrain issue, as I have not have my tires roadforce balanced. I did have them balanced regularly and an alignment done when I bought the car. I want to bring the vibrations up just in case it can lead to a diagnosis by the wonderful people in this forum, and it seemed to creep up around the same time as the shifting issues did.
Wow, that was a lot to type. The shifting issues seem to me to be software related? I really need some help on this one. I do plan on doing the transmission fluid change at 70,000, and I am currently at 65,000. My plan was to discuss this with the indie shop that I will be going to, but I really want to drop it in here first. Any help is much appreciated!
Why not do it now? Be sure the torque converter is drained in the process, and change the filter. Use the correct fluid, not a "fits all " fluid. Verify, but I think yours probably needs MB 236.17 fluid. Make sure the software is up to date, and reset the adaptations after the fluid change. Then, try driving it in the mode that is giving you problems. Hopefully, it is not a hardware problem.
You used your scanner to reset the adaptations and didn’t mention getting any transmission codes, so can we assume you didn’t get any? It would be unusual to have a hardware problem without trouble codes.
I’m thinking that your shift problems could be transmission fluid that has lost its friction characteristics and a clogged filter. The pan has to come off to change the fluid and the residue in the bottom is a very good diagnostic indicator. If there is anything wrong there, a competent shop will bring it to your attention.
I changed the transmission fluid in my 2015 GLK350 at 60-65k miles and it went trouble free until it was involuntarily retired at 155k miles.
If the issue had to do with fluid that needed to be changed, then why would resetting the adaptations solve the problem for about a week? That’s what I’m struggling to wrap my head around. I suppose in my head I was including fluid into the “hardware” category, meaning there is physically something wrong down there vs a pure software problem.
You mentioned that you changed your trans fluid at 60-65k. Were you experiencing anything odd that made you do it early?
You just bought a vehicle and have no idea how it was beat up and no idea if it has trans fluid in it !! And no idea if it’s burnt crap, But a month ago it starts acting up bad like it’s going to need a new transmission, but you say “ oh I’ll just wait 5000 more miles to change the fluid” geez wake up. I think you just found out why the last guy sold it.
Silver Shadow (02-06-2024)
The transmission fluid 100% needs to be changed. Just wanted to throw my symptoms on here to see if anyone experienced anything similar.
I dread experiencing what has happened to you. Have your parts purchased at FCP euro, it’s going to be expensive, just an oil change 500+, and hopefully just rebuild the valve body but who knows.
Is there any clunking from the front when shifting ? You need to check all cv and u joints.
You seem to be leaning towards valve body as being the suspected culprit? Would valve body issues be temporarily resolved by resetting the adaptations like in my case? I did read a thread about the PMW Solenoid being the culprit of a jerky transmission, but the users claimed resetting adaptations didn’t do much.
As far as the clunking, the only time I feel anything like that is the 4-3 downshift that I described above, which happens maybe 20% of the time. It’s fairly rare. It doesn’t feel specifically like it’s coming from the front end, more the mid? Like under my seat ish.
I'm not a big fan of flushing. Usually it means they're not going to drop the pan and change the filter. The torque converter has a separate drain plug. Make sure they take it out and drain the converter. Also, as Piggy pointed out, changing the filter is a must especially given your issues.
If they don't drop the pan, then likely they're not changing the filter. So be sure to specify "drop the pan, replace the filter."
I'm pretty sure there is a bolt for the TC, but you have to know where to look for it once the pan is dropped.
1) Disconnect the transmission cooler line going to the cooler (or radiator internal "cooler", if that's what your car has)
2) Insert the line into a calibrated container
3) Start the engine long enough for two quarts (liters, if you prefer...) to flow into the calibrated container
4) Add two quarts / liters of fresh fluid
5) Continue until only "new fluid" is flowing out of the cooler line
6) Reconnect the cooler line and top off if necessary
7) While the above will result in getting the fluid level back to where it was, you might want to do the proper procedure to make sure the level is where it SHOULD be... (45°C, IIRC, after shifting through the gears a time or two, just a dribble flowing out the drain hole from the standpipe
There is on mine!
Mercedes Automatic Transmission Torque Converter Drain Plug - Genuine Mercedes 0019901117
Unless they use a transporter or some sort of matter trans-muter, there's no way to change the filter without removing the pan.
After reading through the responses in here, I think the first step is definitely to go ahead with the full fluid and filter change out, resetting the adaptations, and having the software checked out with STAR.
My hope is that this resolves the issues. Would a STAR system be able to diagnose a potential hardware issue? Such as solenoids?
I'm not sure what you mean by a "software issue". Either you have the correct software load, or you don't. It's not like it is self modifying code that made a mistake...
Also, I’ve read some threads about people claiming that a software reflash has resolved some issues, but not sure on the specifics.
Most likely new fluid and filter will make quite the difference, along with adaptations reset as part of the typical tranny (can you even say that?) service.
Suggest you reserve judgement and further wonderings until AFTER service is done
