GLK350 2011 Wheel bearings?
WHen in drive and rolling I hear a whining sound. When parked noise goes away. Not loud, could it be wheel bearings or something else. Mechanic can't look at until after the weekend.
The normal "wisdom" is that if it's a wheel bearing, the noise will change when you go around a curve (at a high enough speed to produce some G-force). If the car is a 4Matic, and teh noise is coming from the "middle of the car", it could be transfer case bearings, or if you are luckier (though not "lucky") it could be a front driveshaft (aka propshaft).
Could be the one year old driveshaft. Particularly if you went with a no-name part.
Kinda the same with the wheel bearing / hub. You might get away with it, or it might go belly-up in a short while.
When I'm looking at replacing parts, and deciding between MB, OEM-quality, or "aftermarket", I balance the potential cost savings against how much effort is involved in re-replacing the cheaper part if/when it fails. Both the driveshaft and hub are a lot of work to swap, so I'd suggest using the best parts you can afford. Otherwise the ultimate cost is likely to be MUCH higher for "cheaper" parts (particularly if you are paying someone else to twist the wrenches).
Not an assumption, but a distinct possibility (believe it or not, the Internet doesn't revolve around your needs only, but we post for others to learn a thing or two).
But not to worry - I'll put you on ignore so I don't bother you in the future.
Bill F (05-20-2024)
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
This is what I purchased last year. I always go with Timken.
Never knew MInd reading is was a skillset hahaha
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
https://partsavatar.ca/kugel-front-w...ring-70-510108
Thanks for Timken brand. I am in Canada this source recommended by repair shop. I am surprised the price is ~ 100% less than amazon.
I put a cheap wheel bearing on a vehicle once. I'll never do it again. It lasted 18 months and failed.
Is that the same as saying to pay more a mercedes but all ratings is saying a toyota camry is better? Or more like: Joe at the gas pump said Jeep is better than mercedes GLK350, buy a jeep.
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
I agree with @Silver Shadow ... only go with known quality parts. I myself would NEVER opt for Kugal (a made in China product, which is why it's cheap, price wise) bearing replacement
https://www.amazon.com/KUGEL-Professional-BEARING-70-512220-Rear/product-reviews/B07DZXZ4TH/ref=cm_cr_getr_mb_paging_btm_3?ie=UTF8&reviewerTyp e=all_reviews&filterByStar=one_star
I wouldn't have expected that.
m00nd0gy (05-22-2024)
Wow the OEM bearing is cheaper than Timken: 221-981-04-06-64 - Bearing 2007-2018 Mercedes-Benz | Mercedes-Benz USA Parts (mbusa.com)
I didn't even notice Canada, oops.
2007-2018 Mercedes-Benz Bearing 2219810406 | MB Parts.CA
