Mercedes glk 350 2013 front differential leak
Old Aug 5, 2024 | 07:18 PM
Dourah's Avatar
Glk 350
Hi guys my front differential is leaking I was wondering can I replace the seal in red on the image without dropping completely the front differential, like can I do it on the car?
Here's the exploded of the front différentiel i need to replace the seals in red
Old Aug 5, 2024 | 07:50 PM
Dourah's Avatar
Glk 350
Pinion gear assembled I think
Here's i think the pinion gear assembled
Old Aug 7, 2024 | 06:53 PM
TimC300's Avatar
I havent done it but I would try without dropping it. Get it on a lift and see if anything is in the way of pulling that cover off.
Old Aug 7, 2024 | 06:56 PM
Dourah's Avatar
Glk 350
Thank you for the picture really , I think yess maybe it's doable maybe to be honest @
Old Aug 9, 2024 | 07:58 AM
Mmr1's Avatar
2013 glk 350
Look at AT 205 sealer , Scott Kilmer says he has used it for years with very good success
Old Aug 9, 2024 | 02:33 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
There's a thread here somewhere about how to r&r the prop shaft. If you can get that out you should be able to pull the pinion carrier out. Make sure you get it back together exactly the way it comes apart.
Old Aug 9, 2024 | 03:51 PM
Dourah's Avatar
Glk 350
What do you mean by r&r properly shaft, do you mean the front driveshaf?
Old Aug 9, 2024 | 04:30 PM
John CC's Avatar
Prop == propeller. "Propeller shaft" is old guy speak for "drive shaft".
