Failure to start after battery change
Tested battery voltage 12.75V on the posts. Also the same on the ground stud and positive flat terminal box. For good measure I swapped out the battery with my truck, which happened to be the same size, the behavior remains unchanged.
Ran codes on a cheap OBD2 reader, which yielded nothing.
I've been reading up on a lot of posts about the steering ESL and EIS issues, but I find it very coincidental that either of these devices would just stop working for the first time at the exact same time I had the battery out for 12 hours. I'm debating buying a better code reader to see if anything shows up.
Not really sure what the next best step is. Local repair shop is quoting $300 for diagnostics and $1,800 for ESL replacement if that turns out to be the issue (plus towing).
I work on all my cars, primarily Toyota and Nissan, and have tackled some decent sized mechanical jobs on those, but this is a new one for me.
Can anyone point me in the right direction?
If it’s not a daily driver there are places that rebuild the steering lock , I think it’s just Brushes for the motor but don’t know. there are ways to not spend a fortune if you don’t need it for awhile .
Also, when a battery's voltage shows 12.6v that's generally considered undercharged, so it seems your overnight charging didn't do a whole lot of good for a "new" battery.
I would suggest you take it back to the store and get the proper AGM one, install it and then hook up your trickle charger for overnight charging. Make sure you also lock the doors overnight, that way the car isn't actively searching for the key-fob signal and draining the battery further.
Right now I’m charging a friends old wet cell , it went to 14.65, it settled at 13.8. 12.75 is not what a New battery should read . New off a charger should be 13 or so
I put a trickle charger on all our vehicles every two weeks (even the zero turn!). A maintenance procedure many folks avoid.
