New springs are higher
Old Nov 17, 2024 | 04:20 AM
Mmr1's Avatar
2013 glk 350
13, 350, I put on new sachs rear springs . They are supposed to be oem. But ride hight is maybe 2” higher. Will they settle lower ?
Old Nov 17, 2024 | 04:36 AM
MBKLUE's Avatar
Yikes:
I cannot imagine they would settle that much. Seems like a huge amount.
Old Nov 17, 2024 | 09:36 AM
Mmr1's Avatar
2013 glk 350
Maybe after driving they settle down ? I’ve only had them on 1-200 miles
Old Nov 17, 2024 | 10:23 AM
MBKLUE's Avatar
Yikes:
I'm sure they will but I would think not very much.
Old Nov 17, 2024 | 04:13 PM
Mmr1's Avatar
2013 glk 350
Maybe “factory Oem” are lies. It would not cost that much to remove and cut off some. And ride is rougher
Old Nov 17, 2024 | 05:20 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Hmmm. Were the original broken? How are you determining the new are 2 inches higher?
How I do it ... remove original, then put the original next to the new and place a level across both at the top.
Significant difference (?) Question the new before installing it. 2 inches is significant, if original are not damaged.
Installed correctly? Double check it
Old Nov 17, 2024 | 05:28 PM
Mmr1's Avatar
2013 glk 350
Glk just looks 2” higher . I didn’t think to save them and compare springs or check before since my first time having them done .
Old Nov 17, 2024 | 06:21 PM
habbyguy's Avatar
2011 GLK 350 4Matic
There's no way they're going to settle anything close to 2". Why did you swap springs? I'd never, ever, ever swap springs unless one was broken or dangerously rusted. The chances of a change in ride height or dynamics is just too high (as you discovered). I just got done putting some new struts and shocks on, and swapped the front springs over to the new (Bilstein B4) struts, and ended up with a perfectly dialed-in stance (just like before the swap).
Old Nov 17, 2024 | 08:24 PM
Mmr1's Avatar
2013 glk 350
One spring broke about 1/2 a turn down. Yes I regret the expense , time and result . It was fine before, just noise on big bumps. After the broken piece was removed it was ok. I put in shocks, mounts and springs . Oh well I learned.
Old Nov 18, 2024 | 12:49 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
A couple of things here.
First, you sound like you replaced everything. The old springs may have started to sag. The shocks are gas filled and if the old ones were down a bit the new ones will contribute. Then the spring bushings were almost certainly compressed after 10+ years. You might be only seeing an inch or so more height than when it was new.
Next, the original springs were matched to the dry weight of the components installed on your GLK. There are probably 5-6 spring stiffnesses (rates) identified by color bands painted on them. Aftermarket springs are often available in one or two sort of average versions. But after 10 years, only 1-2 of the original spring rates would probably be available, too.
You didn’t have much choice with a broken spring.
Old Nov 18, 2024 | 08:48 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I used Sachs springs to replace my two broken springs. I measured the old springs as best I could and decided they were the same free length as the new ones, and the wire diameter was the same as well as the number of coils and coil diameter. Those are the parameters that are critical to the spring rate. The alignment shop told me it was too high in the back but that was only about 2 miles after I replaced them. There are different thickness pads you can get. Did you use the old ones, or replace then? (Did you get new anti-corrosion shims for the bottom?)
The factory measurement for rear height is performed by measuring the angle of the rear half shafts with the ground. Essentially, they should be within a couple of degrees of level. I didn't have an alignment rack to put it on, but I parked it on the flatest and levelest part of my driveway and crawled under there on my back and measured them. My conclusion was I was at or maybe half a degree past (within) the spec. If you have a level that reads degrees, you can do the same thing. If your drive isn't level and you get different readings on each side, take the average. The correct value depends on option packages as well as up to vs. as of "model refinement package" (2012?). Values range from -0.78 degrees, +/- 0.6 degrees to +4.75 degrees +/- 1.0 degrees.
