Wheel change assist roller
Old Dec 19, 2024 | 05:21 AM
MBKLUE's Avatar
Yikes:
I guess this could be classified as an unnecessary toy, over-kill, nice to have item or a possible back saver, for mounting/removing wheels...
You crank the little handle to raise or lower the wheel so it is in line with the hub, height-wise. Then, because of the long rollers the wheel sits on, you can easily rotate the wheel until the wheel mounting holes line up with the threaded holes in the hub and then insert the wheel bolts (screws).
Old Dec 19, 2024 | 08:18 AM
streborx's Avatar
Top Answer: 1
G550
If it could lift the wheel high enough to store on my tire rack, yes! Can you provide us a source for this item?
Old Dec 19, 2024 | 08:25 AM
MBKLUE's Avatar
Yikes:
only lifts a few inches. it's from Europe. no idea if it's sold elsewhere. of course there may be a similar item made/sold in North America.
https://www.bs-schweisstechnik.de/ra...2KrdAzxogdQP9d
Old Dec 19, 2024 | 11:02 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Wheel dolly. These are great.
Old Dec 19, 2024 | 11:15 PM
habbyguy's Avatar
2011 GLK 350 4Matic
I figured someone would post a reference to the vehicle positioning dolly - really pretty much the same thing, but with the ability to scoot the car around in any direction, as long as you buy four (and have a level, smooth garage floor).
And FWIW, they do have a much less spendy option - about $65 for a pair, though they're not as easily adjusted or capable of lifting the car (at all). Still, if you just slid one under your tire as you are unbolting it, and carefully raised or dropped that corner with your jack, you could still use it to place a wheel in position without straining (well, other than pumping the floor jack).
https://www.harborfreight.com/2-piec...ies-67338.html
Old Dec 20, 2024 | 12:40 AM
MBKLUE's Avatar
Yikes:
I have a set of GoJaks to move vehicles around but don't use them for wheel mounting or removal. You have fixed steps (teeth) to raise/lower rather than infinite adjustment (crank handle) and it's not easy to rotate the wheel to line up the holes. With the other device the wheel rests on rollers with ball bearings. Very easy to rotate the wheel C.W. or C.C.W. in tiny amounts, to line everything up and no annoying foot pedal that gets in the way or has to be locked down.
Old Nov 5, 2025 | 09:01 AM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Put on my Winter wheels yesterday. At 77 I find they get heavier every year just hanging in my garage!
Old Nov 5, 2025 | 09:28 AM
MBKLUE's Avatar
Yikes:
That's nothing. I drive to the office after each weekend and find that they have added another step to the staircase going up to the 3rd floor. They do that crap on the weekends thinking nobody will notice on Monday morning.
Old Nov 5, 2025 | 12:52 PM
mogulman's Avatar
2013 GLK350
I just have a stainless steel pin that I screw into the hub. Roll the tire out and lift it into place and hang. Isn't that hard but a little lifting.
Old Nov 5, 2025 | 03:45 PM
TimC300's Avatar
My parking area is gravel so probably wouldnt work so well. I use a 2-wheel dollie just to move the floor jack around.
I usually jack the car up so the wheel is 1" off the ground so its a short lift to mount it back on when kneeling. The lip on the hubs do a good job holding the wheels on as long as one hand is keeping it from tilting. I'll have a wheel bolt in the socket ready to screw it in.
One of the best investments I made was getting a Dewalt DCF901 impact for removing the wheel bolts. Just as long as they are properly torqued. I dont use it for installing nuts and bolts though, just removing.
Old Nov 7, 2025 | 07:55 AM
streborx's Avatar
Top Answer: 1
G550
Harbor Freight also sells a set of wheel hanger pins -- 2 each of 12mm and 14mm x 1.25 & 1.5 (8 pins total) that fit most Euro cars. Really helpful getting the wheel onto the hub so the lug bolts can be easily installed.
Old Nov 7, 2025 | 09:52 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Or, Amazon will sell you just the one you need:
Amazon Amazon
Old Nov 7, 2025 | 10:59 AM
MBKLUE's Avatar
Yikes:
I have the various wheel hanger pins for my different cars. Still prefer my roller gadget when the car is near the floor :-)
