Glk250 high fuel pressure P0088
Is there a common culprit that causes this?
Occasional stutter at idle may be related
Backstory: I had the shop replace the valve gasket because I could not guarantee I'd do it without contaminating the fuel system. The engine light came on soon after that repair with those codes but the shop claimed innocent / coincidence.
The shop suggested the new fuel rail but their price was insane. Did it myself. They charged me to clear the codes and we found the high pressure code comes back. They suggested a fuel filter and low pressure pump 🤔. That made me question life considering it's a pressure too high code.
So I've come to the true experts. Any ideas? Please help. I can't afford these repairs.
*I have a scan tool now that can read fuel rail pressure and reset the codes.
*Sometimes the code takes a minute to come back or even have to drive a up my driveway.
- Leak off test
- replace leak off line
- replace high pressure pump
- replace fuel filter
- consider I got a bad fuel rail ( was new Bosch part )
- rebuild injector ( can I narrow down the culprit?)
The pressure buildup is made by the valve on the high pressure pump and after some time the valve from rail begin to regulate.
injectors are not likely the problem. If one or more were bad, you would run pretty rough, and likely have a CEL and accompanying misfire code.
Fuel rails themselves tend to not fail, since they are really just tubes that get fuel from the high pressure pump to the injectors. I would not look here.
Fuel filter and pump assembly. This is all within the fuel tank, feeds fuel at lower pressure but higher volume to the high pressure fuel pump. When this pump and filter assembly is failing, it tends to result in difficult starting, because it is not getting enough fuel to the high pressure pump. I would not rule this out, but would also not consider it the most likely culprit.
High pressure fuel pumps can fail, but you want to be super-duper sure before that one. They are expensive, and don’t typically fail.
What you refer to as the “leak off line” I assume is the fuel return line. This sends excess fuel from the rail back to the tank. This is controlled by a valve. If this valve fails, you may experience either high or low rail pressure, depending on how it fails. This is definitely a possible culprit. Not 100% sure, but this valve likely has an electrical connection. I would verify that this is actually connected properly. It’s a simple thing that can cause problems, and if not connected properly would likely result in consistently high pressure.
You did not mention the pressure sensor. These can fail, and cause error codes like what you are seeing. These are relatively cheap, and I have seen them fail on other cars.
Fuel delivery problems can be hard to diagnose without the right software. If you don’t have the software yourself, you should find a mechanic who does, or buy it yourself.
good luck and keep us posted.
I'd have to agree to narrow down the possible issue.
One odd habit I have (among many) is when I'm in this forum, and reading a thread, I always scroll down to the last Reply ... then I scroll down a little more and will see a section named, "Related Thread".
There's one for your post. And although their problem is "P0087 Low Fuel Pressure", there are some great Replies in there (started Jul 2021 thru Jan 2025!), to include some in-depth troubleshooting.
Also, I HIGHLY recommend that you first go to Reply #2 by "konigstiger" ... in their Reply is a PDF document:
"Introduction of the M276 and M278 Engines", produced by MB ... lots of great detail, to include nice detailed images. Here's the thread:
https://mbworld.org/forums/e-class-w...re-sensor.html
Which “valve gasket” did you have them replace?
One odd habit I have (among many) is when I'm in this forum, and reading a thread, I always scroll down to th....
The fuel rail in the om651 includes the pressure regulator and sensor. That's why it was suggested to change it out in the first place.
I was able to confirm that the stutter I have at idle does coincide with an increase in fuel pressure on the fuel rail. Thoughts on what might cause the stutter?
Last edited by Adam Gallant; Jun 6, 2025 at 08:07 PM. Reason: Added new information
My scanner only updates about once a second so I don't know the true value of how high it goes.
Thoughts on what would cause this
Captured spike in pressure. Normally it's 270bar. The RPM drops too
Also, are you certain of the ordering of spike and stutter?
Replaced lift pump assembly, lift pump drive module, High Pressure fuel pump, no difference. Along the way testing air charge boost leaks, turbos wear. Codes persistent and 0087 show up at just revving it. No xentry diag. to dig dipper.
Any help is much Appreciated
After talking to dozens of mechanics a shop finally told me they didn't know what was wrong (didn't charge me hours thankfully) and asked that I try Mercedes again and see if there's a Learn In software that had to be run.
I had asked Mercedes before but this time I got somebody new and they told me that it was a thing. Unfortunately when I brought it to Mercedes, who I hate, they ran the computer for nearly 2 hours of me sitting there and told me it didn't work. I want to sell this car. I've had so many problems, so when they asked if they could look further into it I reluctantly said yes. They drove me home and by the end of the day they finally called and said you can come get your GLK. IT WAS FIXED THE CODE WAS GONE. What did they do? Apparently "found more modules that needed to be trained". What BS.
Now I have a light for my coolant. I replaced The water pump and I'm not quite sure why I'm getting the code because it comes on so rarely, but I think there's a small air bubble in the system. And I can't just run the car in the driveway because the diesel doesn't warm up enough to burp the system unless I'm out driving. This isn't a great winter Court for that reason. My toddler's car seat is always freezing no matter how long I idle the car before we go.
