MERCEDES GLK 350 2013 BLOWER MOTOR INSTALLATION
Old Feb 5, 2025 | 02:11 PM
Dourah's Avatar
Glk 350
Hi guys I've removed my blower motor but can't seem to be able to install it, it won't seat flush so I can turn it, anybody have some tips, it's the same as the original from behr mahle oe parts?
Old Feb 5, 2025 | 03:48 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
There's several how to videos on youtube.
Old Feb 5, 2025 | 03:49 PM
Dourah's Avatar
Glk 350
Yess but they dont show the part where they installed it?
Old Feb 5, 2025 | 03:51 PM
Sorry, that's not much help. I'll be replacing mine as soon as it warms up a bit. It's screaming like a burning witch!
Old Feb 5, 2025 | 06:40 PM
Mmr1's Avatar
2013 glk 350
Does it match the old unit exactly when you measure it? Maybe just a defective unit ?
Old Feb 5, 2025 | 07:04 PM
Dourah's Avatar
Glk 350
Yes it's the original really they just removed the Mercedes logo so I don't know why it's not flush!
Old Feb 5, 2025 | 07:59 PM
Mmr1's Avatar
2013 glk 350
Return it and buy from FCP Euro or MB ,
Old Feb 5, 2025 | 08:10 PM
Does it push in and twist, locking it with those black plastic tabs? Perhaps it needs to be oriented differently. See if the tabs will engage in a different position.
Old Feb 5, 2025 | 09:36 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Yeah, look for one tab that's different from the others, then find a hole that matches.
Old Feb 5, 2025 | 09:52 PM
Dourah's Avatar
Glk 350
I'll try that thank you
Old Feb 5, 2025 | 09:53 PM
Dourah's Avatar
Glk 350
On the blower motor?
Old Feb 6, 2025 | 04:21 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Originally Posted by Dourah
Hi guys I've removed my blower motor but can't seem to be able to install it, it won't seat flush so I can turn it, anybody have some tips, it's the same as the original from behr mahle oe parts.
Make sure the upper rim of the blower cage is “exactly” the same diameter as the original one. It’s a very tight fit. Also make sure nothing had dropped down into the hole where the blower cage fits, like a rubber gasket or a piece of insulation, etc. Then rotate the housing to get the correct orientation. IIRC it only goes in one way. I fought mine for half a day.
Old Feb 6, 2025 | 06:37 AM
Dourah's Avatar
Glk 350
Thank you I'll try that.
Old Feb 6, 2025 | 01:57 PM
KanataSteve's Avatar
2013 GLK350 Canada
I've had mine out a few times, yes it's tricky. Got to make sure it's oriented correctly and push into place and rotate and make sure that the loose wires don't get trapped in the opening (tuck them out of the way).
One thing that helped me a lot was to have a bright light to see in there, but what really helped was to loosen all the screws on the right side of the dashboard / glove box / everything else because it was such a tight fit. All the plastic pieces were just too tightly jammed together. Once I did that it twisted in place easily. Just be sure you are starting it in the correct orientation before trying to twist it on place. If not correct, it'll never work.
You'll get it!
Old Feb 6, 2025 | 02:30 PM
Dourah's Avatar
Glk 350
You'll get it!
thank you so u advise I removed the glove box for installation?
Old Feb 6, 2025 | 03:39 PM
Dourah's Avatar
Glk 350
thank you
So you advise to remove the glove box?
Old Feb 6, 2025 | 09:10 PM
mogulman's Avatar
2013 GLK350
I had a hard time screwing mine in. I believe I ended up removing the plastic panel by the glovebox on the right side of the dash (between the passenger door and the dash). I remove a few other screws. I had to push the dash/plastic in order to get the blower to fit. I think my dash wasn't exactly lined up perfectly, so in order to get the tabs in, I had to push everything around to get it to line up.
Old Feb 6, 2025 | 09:26 PM
Dourah's Avatar
Glk 350
Alright thank you I'll try that!
Old Feb 7, 2025 | 05:49 PM
Bertie_'s Avatar
GLK350, SL500 (R230), E55 (w210)
There was a small plastic tab on mine that was different from the OEM unit, it prevented the final "twist" because it hit another plastic piece.
I compared it to the OEM one side-by-side, took a file and trimmed down the small plastic hook, after that it went right in
GL
Old Feb 8, 2025 | 04:56 PM
Dourah's Avatar
Glk 350
GL
I'll look into that too thank you
Old Feb 8, 2025 | 07:40 PM
John CC's Avatar
If you look at the photo you posted on post #1 it looks like the tab facing you is not as wide as the ones on either side. If so, that narrow tab has to go in the matching narrow slot in the box.
Old Feb 8, 2025 | 11:28 PM
Dourah's Avatar
Glk 350
u mean this one has to face the arrow on the box?
Old Feb 9, 2025 | 10:26 AM
John CC's Avatar
I'm not sure where the confusion is coming from. The wide tabs won't fit in a narrow hole.
Old Feb 9, 2025 | 10:28 AM
Dourah's Avatar
Glk 350
Oh okay I see?
Old Feb 9, 2025 | 10:53 AM
2013 GLK350 Canada
Hi, was away and unable to respond.
I did not mention to remove anything, simply loosen the screws mentioned. It seems that mine was a very tight fit against other parts and simply needed a little more room. I gained a little more room for the assembly to fit by loosening the screws in surrounding plastic pieces (this allowed other parts to move slightly, out of the way). To be totally honest, I don't remember removing the glove box, but it was a while ago and sometimes memories fade, lol. I do remember pulling on the lower lip of the dash assembly to try to move it away from the heater system. I then easily (luckily?) fitted the assembly into place. You must install it in the correct orientation or it will never fit.
When you have the fan assembly installed, rotated, and locked into place, re tighten all the screws that were loosened. Definitely a difficult fit!
