Error code P204C 2014 GLK 250 Bluetec (Canada)
Old Feb 8, 2025 | 11:42 AM
fyyff's Avatar
Error code P204C and P062A 2014 GLK 250 Bluetec (Canada)
Hello everyone, i am new member here, and just recently bought my first Mercedes Benz GLK 250 Bluetec 2014 (VIN-number WDCGG0EB0EG216671)
Status: Rebuilt, damaged was minor, front and rear bumbers.
After i drove approx 300 kms, check engine light showed up. I have cheap OBD scanner and it is showing me code P204C and P062A (00) (active)
I try to delete the code, and after 2 days it is showed up again. It says: “Reductant pressure sensor - circuit low” status: Permanent. And Fuel pump (FP) A - control circuit range/performance
I was done with car only one thing, i changed Auxiliary battery, for my best knowledge, this car wasn't driving too much with low auxiliary battery.
In general, no problems with car, pulling up good, driving fine, fuel consumption also normal (7-9 L/100 km, city)
I try already search up about this sensor, but didnt find any information, even a part number, hope for any help here.
Thank you!
Old Feb 9, 2025 | 01:54 PM
300SE1993's Avatar
2012 S350 Bluetec, 2014 GLK250 Bluetec, 2026 E350 4Matic
It looks like Canada may have AEM warranty and you may be able to get this fixed for free. Worth looking into.
Old Feb 9, 2025 | 01:59 PM
fyyff's Avatar
Car is more than 10 years old, i think its expired already, but i want to try anyway.
Never doing this before, i should go to any MB dealership?
Old Feb 9, 2025 | 03:48 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Try
https://bluetecupdate.mercedes-benz.ca/en/home
https://bluetecupdate.mercedes-benz....ent-disclosure
https://mbworld.org/forums/m-class-w...nt-canada.html
Old Feb 9, 2025 | 04:10 PM
DenisMcG's Avatar
Veteran: Canadian Forces
2015 GLK 250 Bluetec
AEM was completed in 2022. It should still be under warranty. Although the warranty may be invalid due to the rebuild. Even if the warranty is valid. The fix may not be covered.
WDCGG0EB0EG216671 2014 Mercedes-Benz GLK250 BLUETEC 4MATIC
Status
Vehicle (VIN) Eligible for Field Measure?
Yes
Field Measure Available?
YesField Measure Completed?
Parts
Replaced
Software Update
NOx, PM Sensors
DOC
DPF
SCR-Catalyst
Lambda Sensor
YesVehicle has Extended Emissions Warranty?
This vehicle had a Field Measure performed on 2022-09-27 and mileage at 123237 kilometers. The Extended Modification Warranty period shall be the greater of: (i) 10 years from the date of initial sale or 193,000 kilometers on the odometer, whichever occurs first; or (ii) 4 years or 77,250 kilometers from the date of installation of the Field Measure, whichever occurs first. Please contact your local Authorized Mercedes-Benz Service Centre or our Customer Assistance Centre at 1-866-352-2710 for information on your coverage. You can find additional information on the terms and covered components by clicking on the link below.
Old Feb 10, 2025 | 10:46 AM
andreigbs's Avatar
GLK 250
Worth a trip to the MB dealer, for what is likely a covered DEF system failure.
