Glk350 problem
Old Mar 17, 2025 | 11:52 AM
Redeyedzombie's Avatar
2014 glk350
Glk350 problem
So I have a glk350 that had the fuel smell in the cabin. Took that to a shop and got that fixed. After that it started randomly dying while driving. Replaced both fuel pumps and they sent the computer to be reflashed I believe. It still has the same issue. They then said it was a module under the rear seat but basically told me to come get the car from there shop. I don’t know much about these cars so any help is appreciated
Old Mar 17, 2025 | 12:27 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
You mention "glk350", but no year and sub-model. Mileage would also be useful.
You state, "module under the rear seat and to come get car" ... does that mean they replaced the module?
So, it still randomly dies. Has it been scanned for error codes? If yes, which one(s)?
Does it ever go into limp mode - or engine simply shuts down? Does it only die coming to a stop, or while in motion?
Old Mar 17, 2025 | 01:21 PM
habbyguy's Avatar
2011 GLK 350 4Matic
The fuel smell is because one of the two fuel-related devices under your rear seat cracked. A very common failure.
The configuration varies from model to model, but basically one will be a fuel level sender, and the other a fuel pump. But the system is "complicated", especially the fuel pump side. It sure sounds like the shop botched the install, and/or installed a bad part (off-brand parts for this application are notoriously bad, and can fail out of the box). At any rate, it sounds like you're dealing with a shop that knows nothing about the GLK (or Mercedes in general, since the GLK is very similar to many other, more common MB vehicles). You'd do well to have the car scanned with an MB-specific scanner, or at least a full-featured bi-directional scanner that can figure out what's wrong with the fuel delivery (or whatever else is causing your problems).
Old Mar 17, 2025 | 01:22 PM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Also:
Who are “they.”
An MB dealer? An independent MB or German car shop? An independent general repair shop?
Flashing the ECU is a rather unusual repair tactic.
The VIN would be useful so anyone replying could see what equipment was included on your GLK.
Old Mar 17, 2025 | 01:30 PM
2014 glk350
Originally Posted by Odd Piggy
Also:
Who are “they.”
It wasn’t a MB dealer.
VIN# WDGCC5HB2EG196738
Old Mar 17, 2025 | 01:36 PM
2014 glk350
It’s a 2014 with around 220,000 miles.
They did not replace the module and basically wanted me to get the car off there property. Turns out they are now under investigation.
It doesn’t go into limp mode. Sometimes it dies while driving and sometimes it dies while trying to accelerate from a stop. It was scanned I don’t remember the codes but I have the paperwork somewhere. I’ll post when I get off work
Old Mar 17, 2025 | 04:00 PM
Odd Piggy's Avatar
lastvin.com say that is not a valid VIN. Can you check that letters or numbers have not been transposed?
Most X204 begin with WDC.....
Old Mar 17, 2025 | 04:07 PM
2014 glk350
Error on my part. WDCGG5HB2EG196738
Old Mar 18, 2025 | 12:23 AM
Odd Piggy's Avatar
Here’s a list of every option and variation you have. It’s called a Data Card. Print it and keep a copy because getting the right parts and fluids depends on the variations.
You have ECO Start/Stop and something could be wrong there. But you will need to get the car scanned with a dedicated MB scanner if you don’t have one yourself. I’ll try to help again tomorrow.WDCGG5HB2EG196738 www.LastVIN.com 1
2014 MERCEDES-BENZ GLK 350 (204.957)
General Data
FIN WDC2049571G196738
VIN WDCGG5HB2EG196738
Model Year 2014
Model GLK 350
Engine 276957 30 532154
Transmission 722906 05 111518
Order Number 0 4 706 04414
Order Location UNITED STATES (USA)
Production Number 1394895
Interior IMITATION LEATHER - BEIGE (125A)
Paint 1 POLAR WHITE (149U)
Release Date 2013-08-16
Delivery Date 2013-08-16
Code Description
01A DAS 3
03A OIL OFFSET AMOUNT +300 ML OIL
120A IMITATION LEATHER
125A IMITATION LEATHER - BEIGE
149U POLAR WHITE
192 STEUERCODE NAG2-GETRIEBE MIT D1 STAND
1U2 SNOW GRID
211 EPS STEERING (ELECTRIC STEERING)
212B 222 232 OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA/CAN
RIGHT FRONT SEAT, ELECTRICALLY ADJUSTABLE
GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUENCY
240 LED DAYTIME RUNNING LIGHTS
245 TRIP COMPUTER / COMPASS
249 INTERIOR AND EXTERIOR MIRROR,AUTOMATICALLY DIMMING
264 LICENSE PLATE ATTACHMENT AMERICA
275 280 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
LEATHER STEERING WHEEL AND LEATHER GEAR SHIFT KNOB
284B AIRBAG LABEL - ENGLISH FOR USA
291 PELVIS AIRBAG (PELVISBAG)
294 KNEE AIRBAG
301 ASHTRAY PACKAGE
342B 345 RAIN SENSOR
INSTRUMENT CLUSTER/HU LANGUAGE - AMERICAN
348 EMERGENCY CALL/SUPPORT SYSTEM
35A VGS D4-0, D3 PATTERN
413 PANORAMIC SLIDING SUNROOF/GLASS SUNROOF
41R LIGHT ALLOY WHEEL 5 DBL-SPOKE DESIGN 20" ALL-ROUND
427 AUTOMATIC TRANSMISSION 7-SPEED
428 442 461 STEER.WHEEL GEARSHIFT BUTTONS/SHIFT PADDLE PAINTED
440 TEMPOMAT (CRUISE CONTROL)
MULTIFUNCTION STEERING WHEEL (12 BUTTONS)
INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
475 TIRE PRESSURE CONTROL
485 (COMFORT RUNNING GEAR)
494 U.S. VERSION
https://www.lastvin.com/vin/YvV1rdZb...GG5HB2EG196738 www.LastVIN.com 2
Code Description
508 NAVIBOX PREINSTALLATION
518 UNIVERSAL COMMUNICATIONS INTERFACE (UCI)
523 RADIO AUDIO 20
536 SIRIUS SATELLITE RADIO COMPLETE SYSTEM
54U ROOF INTERIOR TRIM BROWN FABRIC
551 BASIC ANTITHEFT ALARM SYSTEM (ATA)
580 AIR CONDITIONER
584 ELECTRIC WINDOW REGULATOR
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PRODUCT PROT. F FREIGHT PACKAG. W TIE-DOWN HOOKS
669 722 SPARE WHEEL / FOLDING WHEEL
705L UNITED STATES (USA)
CENTRE CONSOLE FOIL DECOR - BLACK/SILVER (2C03)
725 CHROME LOOK ROOF RAILING
731 TRIM PIECES - WOOD BURRED WALNUT VENEER
763 RADIO REMOTE CONTROL WITH PANIC SWITCH (315 MHZ)
7XXL NORTH AND SOUTH AMERICA
804 YOM 13/1
840 DARK TINTED GLASS
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
889 KEYLESS - GO
890 AUTOMATIC REAR-END DOOR
900 EXTERIOR CHROME PACKAGE
909 ALTERNATOR MANAGEMENT
916 FUEL TANK WITH LARGE VOLUME - VOLUME 1
919 AIRCON COOLING POWER PACKAGE
986 DEVIATING VIN WITH MODEL YEAR
989 IDENTIFICATION LABEL UNDER WINDSHIELD
A20 DIRECT START
A21 SHIFT BY WIRE
A63 FE TORQUE CONVERTER HOUSING-0
A64 FE CONVERTER 0 MM
A89 REDUCED-FRICTION
A99 U-VALVE BODY ASSEMBLY WITH VGS 4-0
B03 B09 DIRECT START / ECO START/STOP FUNCTION
REFRIGERANT COMPRESSOR WITH MAGNETIC COUPLING
B12 WHEEL REPLACEMENT TOOL
F204 MODEL SERIES 204
FX SPECIAL VERSION
G906 TRANSMISSION CODE VERSION 06
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
J4A DSM: STAR1 FBS3 UPDATE
J81 CHANGED OIL FILLING OM613
K15 CONTROL CODE FOR SERVICE INTERVAL 15000 KM
L LEFT-HAND STEERING
M007 CHASSIS WITH 4X2 DRIVE
M276 V6-GASOLINE ENGINE M276
M35 DISPLACEMENT 3.5 LITER
ND8 CONTROL CODE BREMEN PLANT
P76 BASE PACKAGE, EXTERIOR
R02 ALL SEASON TYRES
U10 FRONT PASSENGER SEAT WITH WEIGHT SENSING
https://www.lastvin.com/vin/YvV1rdZb...GG5HB2EG196738 www.LastVIN.com 3
Code Description
U12 FLOOR MATS - VELOUR
U22 LUMBAR SUPPORT ADJUSTMENT
U80 115 V SOCKET
V74 SPEED + LOAD INDEX 100H XL
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
Old Mar 18, 2025 | 05:09 PM
calder-cay's Avatar
Wow - 220k miles - that's great, despite the current problem. And the shop "under investigation" is not a good thing.
Codes ??
