2013 GLK350 washer pump issue?
My daughter bought this car last year, which has been great with one minor issue.
It will not spray washer fluid on the front windshield.
It will spray on the rear.
Things that have been checked/replaced.
- Pump replaced
- Front washer line/hose replaced
What else should I be looking for?
Thank you
- Pump replaced
That’s an odd problem. If the scanner shows the washer stalk button being pushed, but the pump does not turn on, either there is a shorted wire, or the stalk is bad and not sending a signal back to the pump to turn it on. I’d bet on the latter.
I checked for voltage, and I get a momentary spike of voltage when trying the rear washer and no spike when trying the front washer.
When either the new pump or the old pump is connected they both operate when the rear washer is engaged but nothing with the front one.
