Oil leak back of engine
The oil pan / PCV cap is the most common leak area (by far) - other than that, I'd say it is most likely to be a valve cover gasket.
That's a CATASTROPHIC problem ... and because you're questioning "what to do", you better get it to a dealer or qualified MB shop asap.
The only "oil leak" issue we've had on our 2014 GLK Base is because the gasket on the oil filter cover was degraded, which resulted in minimal oil loss.
I would never drive a "1 quart drain in 1k miles" vehicle!!
when I had decent amount of oil in the hose from pcv to the air intake elbow/TB it was isolated to inside the units, no external leaks.
