M276 valve cover torque specs
Old Jul 15, 2025 | 10:48 PM
Dourah's Avatar
Glk 350
Hi guys I looked before posting does anybody knows the
torque specs for the valve cover on the m276 engine?
Old Jul 16, 2025 | 03:51 AM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
Here you go.
File Type: pdf
File Type: pdf
File Type: pdf
Old Jul 16, 2025 | 04:07 AM
JohnnyC's Avatar
Also the bolts are part number 113-990-02-22 and eighteen required per bank. You can reuse the old ones. The specific socket needed is an E-Torx 10. If you cross thread it you won't be able to repair it because the thread is an uncommon M7 size so be careful.
Old Aug 10, 2025 | 11:48 PM
Dourah's Avatar
Glk 350
Originally Posted by JohnnyC
Here you go.
thank you just saw it
Old Aug 10, 2025 | 11:52 PM
Dourah's Avatar
Glk 350
would you advise new bolts to avoid stripping the threads?
Old Aug 23, 2025 | 07:40 PM
JohnnyC's Avatar
The bolts are like 5$ each. Just reuse the bolts.
Old Aug 23, 2025 | 09:50 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Clean the threads on the bolts, and the threads in the holes, and you shouldn't have any problems with stripped threads.
Old Aug 23, 2025 | 09:51 PM
Dourah's Avatar
Glk 350
