Intake Manifold issue 2010 m272
I saw another post mention the pcv and centrifuge, and another saying cam magnets / sensor. Could either of these be a cause? To add I do have some pretty rough oil leaks (seems prior owner was a bum) but nothing that seems hard to fix (there is the correct oil level) Also having a loud tapping (metal sound) that I believe is valves as putting hydraulic valve cleaner in quieted it down (only for a single drive
) could any of these be the reason? Attached a link to video of the noise if it helps.
Thanks in advance yall
On the noise - it really does sound like a "single-source noise", but I have found that using the correct oil makes a big difference... my 2011 X204 (GLK350) was sounding a bit "diesel-ish" running "regular" Mobil 1 synthetic oil, but quieted right down as soon as I switched over the European Car Spec oil (it will be listed as meeting the 229.5 and/or 229.51 specification). Might be worth a change if you aren't running that now (especially if you're due for an oil change anyway).
And of couse, it's always a good recommendation to spend $7 (last time I checked) on a Harbor Freight mechanic's stethoscope. Best tool purchase you'll ever make for a diagnostic tool, IMHO. It might well point you directly to the source of the noise, unless it's internal, deep in the engine (hope not, of course).
