Air Filter change now rough idle
Old Sep 23, 2025 | 08:04 PM
Kartoffel's Avatar
2012 Mercedes-Benz GLK350
I recently changed the air filter on my 2012 GLK350, and now it's running terribly. Rough idle, no power, etc. I have codes but no reader. I've read this can be due to the cover not seating properly, which makes sense as it ran just fine before I changed the filters out. Any tips or other things I can be looking for?
Old Sep 23, 2025 | 08:39 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
Might be a vacuum leak somewhere.
Ensure everything is sealed properly.
Old Sep 23, 2025 | 11:57 PM
Bill F's Avatar
2013 GLK 350 4 matic
Check the filter box to make sure it is placed right and then look around the filters to see if you may have dislodged something.
Old Sep 24, 2025 | 05:49 PM
Kartoffel's Avatar
I'll do that when I get home tonight. This feels the most plausible as I didn't do anything but take the cover off, change the filters, then put it back on (unless I broke something, which seems highly unlikely).
Old Sep 24, 2025 | 07:21 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Just FYI, you are supposed to run "adaptations" after changing the filter, to reset the learned parameters from the old filter. I didn't do it, and things worked out fine, but, if you're supposed to, there must be a reason.
Old Sep 24, 2025 | 07:27 PM
streborx's Avatar
Top Answer: 1
G550
Are you serious? Air filters need to be "registered" like new batteries? What if you only remove the filter, vacuum out the crud and put it back in? The engine can't figure out air mass?
Old Sep 24, 2025 | 07:31 PM
John CC's Avatar
Don't shoot the messenger!
Old Sep 24, 2025 | 07:40 PM
Kartoffel's Avatar
Never encountered that. What does it entail?
Old Sep 24, 2025 | 09:23 PM
calder-cay's Avatar
It entails nothing.
I've changed the air filter three times (you know, put a new one in), and have NEVER done an adaptation or reprogramming or what-not. Simply pop the top, remove old filter, insert new filter properly, snug cover. Done.
It was also mentioned having to "adapt" (or program) when swapping to a new battery. We just recently swapped in a new battery (the big one under the hood) ... zero reprogramming required ... also replaced the Aux battery in the back trunk two years ago ... no programming. This is for our 2014 GLK 350 Base.
I have read where folks got the wrong filter and it caused issues. That will happen with ANY vehicle. Heck, the 2001 Jeep will complain if the air filter is not a proper fit.
Old Sep 24, 2025 | 09:25 PM
W205C43PFL's Avatar
How is that done?
Old Sep 24, 2025 | 09:45 PM
John CC's Avatar
How is that done?
You need a scanner that speaks Mercedes.
Here is the WIS page for filter change. Note particularly step 15.
File Type: pdf
Old Sep 24, 2025 | 09:46 PM
Kartoffel's Avatar
Originally Posted by calder-cay
It entails nothing.
I'll try putting in the old filters again. The new ones are non OEM, so maybe that's it. They fit and all; just regular Fram filters (their higher tier, but nothing special).
Old Sep 24, 2025 | 09:47 PM
W205C43PFL's Avatar
Thanks, seems to be only the diesel models.
Old Sep 24, 2025 | 09:56 PM
John CC's Avatar
There's an old joke. I don't subscribe to it, but it was big 30 years ago:
Friends don't let friends drive Fram...
Old Sep 24, 2025 | 10:15 PM
Kartoffel's Avatar
I put the old filters in and it's still running like garbage. It feels like the air box isn't hooked up, but everything looks and feels right under the hood. I've checked the MAF coupling, the intake hoses, and whatever that air pump is that hooks up in front; all appears well.
Did I break something? How is that even possible? I wasn't manhandling it, but even if I were it shouldn't break this easily. Air filters are easy things to do and there's almost nothing to screw up, right? What an I missing?
Old Sep 24, 2025 | 10:18 PM
Kartoffel's Avatar
The old filters I took out are the same, and it's just an air filter. It's not like I put in cheap sparks or eBay rotors; even a bad air filter is usually pretty decent (and the good ones are often restrictive, so it's not a one to one thing). But even so, a subpar air filter won't make the car run like it's missing half the cylinder banks.
Old Sep 24, 2025 | 10:41 PM
John CC's Avatar
I have to apologize. I was thinking you had a GLK250 (Diesel). The 350 is a whole different animal! Could be nothing I said was relevant...
Old Sep 25, 2025 | 12:22 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Even a very inexpensive code reader like an Autel 329 from Walmart for about $29 may offer an important guide. You won’t get the MB specific sub codes, but the generic powertrain code could point to the location of the problem. And eliminate a lot of guessing.
Old Sep 25, 2025 | 01:46 AM
W205C43PFL's Avatar
All good thanks again for the WIS doc. That said, the adaptation isn't a thing on the gasoline vehicles?
Old Sep 25, 2025 | 08:32 AM
streborx's Avatar
Top Answer: 1
G550
Dumb question -- please don't take offense, but are you certain you have the filter installed correctly for the direction of air flow?
Old Sep 25, 2025 | 10:09 AM
MBKLUE's Avatar
Yikes:
I don't see this being an air filter problem. You should be able to idle and drive just fine with no filter installed. The MAF is measuring the air flow. Even at wide open throttle, without an air filter, you would probably get a bit more air flow than with a new filter but I doubt it would be anything past the abilities of the system to measure and compensate for.
Not recommending anyone drive without an air filter but I think the problem is elsewhere. Loose/bad connection at the MAF? At the intake air temperature sensor? At the MAP, if it has one?
OP: Did you happen to clean the MAF or throttle body with a spray? Since it's not a K&N filter I'm sure you didn't oil the new one. Possible vacuum leak as calder-cay mentioned? Forgot to re-attach some small vacuum hose?
Old Sep 25, 2025 | 10:44 AM
Mmr1's Avatar
2013 glk 350
Yes air filter isn’t the issue , run it without the filter and see. I think you did something else by mistake when changing it. Or try the old filter
Old Sep 25, 2025 | 11:20 AM
W205C43PFL's Avatar
Would those throw a code?
OP seems to have tried putting the old filter back same issue.
Old Sep 25, 2025 | 11:30 AM
MBKLUE's Avatar
Yikes:
A problem with a MAF, MAP or air intake temperature sensor/sensor connection should certainly generate a fault code/illuminate the MIL warning. A "missing" or poorly installed or poorly sealed air filter would not.
The OP could certainly try idling or driving the car (in a clean environment for a short distance) without an air filter(s) as Mmr1 mentioned. I think it will make no difference but a good test just to eliminate a possible cause, if nothing else.
Old Sep 25, 2025 | 11:32 AM
W205C43PFL's Avatar
Makes sense. Wish OP can tell us more once a scanner is plugged in.
