Oil Leak form the drivers side catalytic
Cheers,
(I have a thread posted out here about it.)
Anyway, it turned out to be the oil filter cover (top-front of engine)
Its o-ring seal, over time, had "crushed" flat and oil was dribbling from around it, but IT WAS NOT obvious.
Not obvious, meaning, if you opened the hood and looked at it, you could not see the oil leaking.
The leak was occurring from its back-side and down (and slow leak only during engine-running).
One reason is because the lower engine cover was catching the oil, and when you're driving the oil is pushed back to the back end of the cover and drips , so it's NOT obvious where it's originating from.
I'm not saying this is your issue, but worth checking (5 minutes).
2010-2015 MERCEDES BENZ GLK350 DORMAN - 917-127 - Cam Housing Plug Assembly
Part#917-127
Also, to locate this rear plug, I must remove the rear top cover, I'm thinking this might be the intake manifold?
Part# 917-127
See if this YouTube video is helpful:
The O2 sensors plug into the ecu harness at the top middle rear of the engine. Not sure how oil would leak down onto the wires. May have oil leaking from the vacuum pump that is above the drivers side O2 wires. There is a small round plastic plug at the back of the drivers side cylinder head.
I'm able to hold my phone down in behind the engine and snap photos then view them on my PC. Snap a bunch because most photos come out blurry with space so limited back there.
I cant see oil leaking from the oil filter housing or cooler making tis way onto the O2 sensor wires or exhaust manifold. You would most likely see oil dripping down directly below it if it were leaking.
I believe the O2 wires are in the silver wire covering, connectors circled in red. Plug circled in green. Can see the silver cover of the vacuum pump next to the plg.
Managed to stick my phone back there with the air filter box still on.
