GLS Class (X166) Produced from 2016 to 2019
Need some advise about tires
Old Jan 31, 2020 | 02:34 PM
Jt0230's Avatar
GLS 550
Question Need some advise about tires
Just had a flat on one of my tires, and need to get it replaced. I just had a brand new set of 4 put on about 12,000 miles ago. Can i just replace that one tire or do I need to get two tires. Should I just get one tire and get it shaved down to match the other 3? Thanks for any help. I have a 2017 GLS 550.
Old Jan 31, 2020 | 04:40 PM
JaTe's Avatar
MB GLS450
I shaved down a tire on my last car due to same situation as you and had no adverse issues. Car was also AWD.
Old Feb 1, 2020 | 08:48 AM
Jt0230's Avatar
GLS 550
Thanks JaTE! Surprisingly I got the tires at the dealership because it was cheaper then anywhere else, do you think the dealership would shave the tire?
Old Feb 1, 2020 | 10:58 AM
JaTe's Avatar
MB GLS450
It depends if the dealer has the tool to do it or if they are willing to do it. I just ordered my tire from Tire Rack and they charged $30 to shave it down to what I needed it to be at.
Old Feb 1, 2020 | 10:05 PM
Jt0230's Avatar
GLS 550
Thank you all for the help!
Old Jul 11, 2020 | 08:14 PM
jhpmbusa's Avatar
2021 M550i
correct, has to be all 4 same brand/model and run flats.
Old Jul 17, 2020 | 02:59 PM
Boraxo's Avatar
GLS450
not correct. I had a blowout about 8 months after buying 4 Michelins from Costco. Unfortunately the tires had been discontinued so they ordered 2 of the newer version so that each axel would have matching tires and treadwear. Put 2 new on back and left 2 old on front.
There is no requirement to replace RFTs with new RFTs - many people replace all 4 RFTs with regular tires and carry a patch kit. Though I think it unlikely you would find a shop that would replace a single run flat with a non-RF - you need RFTs on all 4 or none.
Old Jul 17, 2020 | 03:08 PM
jhpmbusa's Avatar
2021 M550i
i was talking about when returning a lease back. haha it might have been the thread above and maybe not this post. This forum has a weird way automatically moving you onto a similar thread.
Old Jul 18, 2020 | 02:41 PM
Boraxo's Avatar
GLS450
same for lease returns per MB dealer. Each axel must be same brand/model (but ok for front/back to be different) - tread req is min 4/32 but all 4 can have different wear. And yes if car came with RFTs must be Lease returned with RFT.
Old Jul 18, 2020 | 03:09 PM
jhpmbusa's Avatar
2021 M550i
oh really? thats good to know. do you have it in writing/publication by any chance? my dealer always tells me it has to be all the same for all 4 tires...
Old Oct 8, 2020 | 08:01 PM
White One's Avatar
016 c450 AMG
Almost identical mileage and the same situation..I replaced one..Its been about 10 months or so..lots of miles and zero issues
Old Oct 9, 2020 | 12:59 AM
wyatt88's Avatar
GLS 450
My GLS 450 was three months old and had 3000 miles when a pothole on a freeway destroyed passenger side front tire. My dealership said it would be fine to replace only that tire. Now 21,000 miles on the car and the rear tires are almost completely bald. The one on the same side as the newer front tire is worn the most. All the tires have different degrees of wear. I have had many SUVs and have never had to replace worn tires at 21,000 miles. In fact our BMW X5 went almost 60,000 miles before it needed new tires.
Not sure the tire replacement on the GLS had anything to do with the rear tires wearing out. By the way the wheels are 19" and the car does not have run flats. Original tires were Continentals put on by the factory.
Do any of you think shaving down the new tire would have made a difference on tire wear with that low mileage? Do tires wear out super fast on the GLS routinely for some reason?
Old Oct 9, 2020 | 03:57 AM
Golfather's Avatar
GLS350d V6 AMG Line G-Tronic
Why not change 2 on the same axel, and keep the one good as an emergency spare...
Old Jan 20, 2021 | 09:04 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
The tiny difference in rotational speed between a new tire and a used one will easily be absorbed by the differentials. Matching or closely matching tires is more about stability in emergencies or bad road conditions.
