May buy 2017 GLS 450 and have questions
With a bright flashlight, look at the front of the cylinder heads where the cam actuators are attached. Check for oil leaking or weeping.
same for under the vehicle, check for oil leaking from the rear of the engine/front of transmission.
I have leaks from both of these areas on an M276 with 33k miles. If the seller agrees to repair leaks, if any, that would be a positive.
Mike
