Pls Recommend Practical New Wheels & Tires for GLS 550
I've had my 2018 GLS 550 since June 2021, but only just experienced for the first time how absolutely horrendous it is in a few inches of slushy snow with its stock tires. Of course, after my harrowing experience of having to stop myself from sliding down my road by turning into the hillside because I simply had no traction to creep down the hill like our Volvo XC90 does, I immediately jumped on the forum and saw many others' similar experiences, along with the recommendation to get better tires, etc. (I have the standard Conti UHP tires, w/10k miles on them, on 21" rims which I now know is the reason gravity overcame any efforts to control my speed down the hill). I live in southern California, and though I'm in the Sierra foothils at 5600' and we do get snow, it's not too frequent and it disappears after a day or two. So I really don't need dedicated snow tires.
I saw many of you switch to smaller wheels for your winter driving, and my husband switched from 21s to 20s on his XC90 and it handles great in rain/snow as well as on dry pavement, which is 95% of our driving. If I'm going to have to spend $2k+ for better tires for all-weather (rather than UHP), I'd rather change out my wheels completely, to have more rubber which seems more appropriate for the type of tame driving and hauling I do. I don't want to sacrifice handling to the extent that it interferes with safety, but I'm not cornering fast or driving aggressively so I'd rather minimize chance of a pothole incident by having more rubber, and also better traction in rain and the occasional snow if possible. Does anyone run 19 or 20" year-round on their GLS 550? Any recommendations on 19 or 20" wheels that would still be essentially Mercedes spec? Recommendations on tires to go with those wheels? I saw Toyo Celsius recommended for year-round, and grateful for other recs.
Thank you!
I now have Michelin Cross Climate SUV tires and traction, stopping, etc in snow is far better. They are still good with 23,000 miles on them.
As an aside you probably know that all GLSs absolutely eat tires.
https://www.wheel-size.com/size/merc...ls-class/2019/
Results: https://docs.google.com/spreadsheets...#gid=742439515
https://www.tyrereviews.com/Article/...-Tyre-Test.htm
https://www.tirerack.com/tires/TireS...erformance=ALL
There is no winter tire test, but you can see both tires compared in dry and wet tests at tirerack:
https://www.tirerack.com/tires/tests...y.jsp?ttid=287
I live out on country roads as well. Multiple rim issues…I just have to slow down.
In Christ,
Steve
Geolanders is what we have on the 450. You'll do better with a narrower thread, if you can fit them on the wheels. The diameter doesn't much matter.
BTW, the 450 has 19" rims. Maybe they would fit. Only reason they wouldn't that I can imagine is if you have bigger front brake disks. We're running 275/55-19s here in northern New England and never had a problem. However, we've both also got over half a century of experience driving in nasty winter weather, much of it pre- ABS, AWD and Traction/stability Control.
Thank you!
However it sounds like you need a vehicle more appropriate to your needs and a GLS550 is not it. The 550 was built for more on road performance oriented driving. That’s why it came with low profile 21” wheels and no other lower tire option size. The front track of the 550 is even wider than the 450. All of this was most likely taken into account with drivability in mind when the engineers chose the 21” tire size. Trying to find smaller tires and wheels for which the car was not designed is counter productive. There are plenty of other vehicles that might check the box for you.
Towing trailers on hilly dirt gravel roads and docile driving with a 449 hp biturbo beast with 21” AMG wheels are 2 different purposes going in the opposite direction.
