GLS Class (X166) Produced from 2016 to 2019
rear spring bags, which aftermarket? gls550
Old Feb 12, 2024 | 08:23 AM
merim123's Avatar
'18 GLS550
Came outside yesterday and the car is all low on the rear. I get in, it starts and lifts right back up. Drove it fine. Did some quick googling, looks like the air springs are an easy replace, but amazon and rockauto all over the map on pricing. Is there a set of bags people like aftermarket that they have had success with or should I just go to dealer and get OEM?
Old Feb 12, 2024 | 10:02 AM
mikey08's Avatar
11 E350 Cab, 18 GLS450
I have the same issue in the rear, I did buy Corteco bags which are OEM without the benz logo. I do not have them in yet but will soon.
They are not the cheapest more more reasonable than paying the dealer the 800 bucks for them with their logo on it,
Cheers
Old Feb 12, 2024 | 10:40 AM
merim123's Avatar
'18 GLS550
where did you get them from? which supplier?
Old Feb 12, 2024 | 10:43 AM
mikey08's Avatar
https://www.germanautosupply.com
Old Feb 12, 2024 | 06:51 PM
PrimeMB450's Avatar
GLS450
Cheers
I didnt know Corteco were oe. I might have to try them out as well. I was going to buy Arnott bags but for 70$ more its not bad.
Old Feb 14, 2024 | 12:44 PM
mikey08's Avatar
Just be sure to purchase the bag retainer clips as they do not come with the bags. They can be bought on ebay or at any dealer for like 8 bucks each.
Mike
Old Feb 16, 2024 | 03:51 PM
mikey08's Avatar
Well I replaced the rear air bags today. One side had oil leaking from the top which to me means the seal was leaking. It was pretty easy, did one side at a time so I did not have to raise the car from the differential. Had it done in an hour. Will monitor and see what happens the next few days.
Mike
Old Jun 16, 2024 | 04:45 PM
FWP!'s Avatar
2017 GLS 550
Just FYI, AutoHausAZ has the Corteco OEM bags for $249, I just bought a pair for our GLS - https://www.autohausaz.com/pn/OE-1663200325
Old Jun 18, 2024 | 01:26 PM
FWP!'s Avatar
2017 GLS 550
I am replacing the two rear air bags today, the right one was starting to sag randomly even while driving which made the handling really poor. When I got the right one off, I wanted to see where it was leaking from, and it looks like it just developed a bunch of little pin hole leaks that the air compressor probably couldn't keep up with.
Video - https://share.icloud.com/photos/03bJ...fpQKPzwxgNsD6g
The left side one was still fine, no leaks that I could find.
Old Jun 20, 2024 | 02:21 PM
thtguy's Avatar
2017 GLS 550
So did MB not do the stupid extra reservoir that requires you to drop the rear subframe like on the W211 chassis. sorry those were the last springs I had to replace. I just cut the resevoir hose and put in Arnotts
Old Jun 20, 2024 | 02:32 PM
FWP!'s Avatar
2017 GLS 550
I did the bags myself. Didn't cut the line, I just re-used the OEM fitting after inspecting it and the rubber o-ring.
Old Jul 21, 2024 | 03:26 PM
johnny--2k's Avatar
2018 GLS 550
Is there anything specific required to put these cars on a lift with the air suspension? Or what about just jacking one side up IE: to change a tire or something?
Old Jul 21, 2024 | 03:38 PM
FWP!'s Avatar
2017 GLS 550
I always just crack one of the doors open. It stops the car from doing anything with the air suspension.
