GLS450 - What is the best FRONT recovery point
I purchased my used 2017 GLS450 almost a year ago and it's been absolutely fantastic so far. I am starting to plan for next years adventures, which includes some pretty nasty forest roads, and I need to know how the heck to pull this thing out of a ditch if it needs to happen from the front end.
I have the off-road package, so much of the undercarriage is covered with skid plates - where the heck can I latch on if recovery is necessary?
I ordered one of these for the rear hitch.
I looked through the OM I don't see any specific mention of recovery hooks etc..
There is this note;
I see you are in Denver. I'm not sure how the elevation will affect the lift capacity. You better check into that, too.
That said, recovering a vehicle that doesn't have a real frame with a winch is always a crap shoot.
Curb weight is 5300lbs, so that'd be easy peasy for those monsters.
I've been reading up a bunch, and I am going to get underneath the car again tomorrow to find a few points I could use in a pinch. My plan is to get some soft shackles, a couple of tree savers, and a 4 ton cable puller / hoist. I am honestly not doing anything super nasty.
I am very aware of the dangers of recovery (i.e. hitch ball is a no-no) so it's the kind of thing I'll try to over prepare for, but fingers crossed, will not need.
The trailer is a 'rolling' 7000lbs - low resistance. So you might be pulling a 7k lb trailer, but I doubt that's the force at the hitch.
A stuck car is very different, so I'd guess that creates a load exponentially greater than the curb weight of the vehicle.
Still I think they should've considered recovery options. I know it's not the G wagon, but it does have the G, so I'd expect a bit of thought put into it.
The information in my G550's OM is mostly worthless. It shows the locations of the front and rear towing "eyes", but says nothing about circumstances of using them. Then there's a sketch showing a G-wagen straddling 2 flatbed railcars with a big "X" through it. I'm not sure how you could ever get any vehicle into such a placement, much less why anyone would think the physical distance between two railcars would permit this. Mostly, all that's said is to disconnect the propeller shaft before towing it, but not where to connect a tow strap.
I guess the best advice for recovery is to avoid circumstances that might make such necessary, and if you find yourself so situated, call a towing service. The only vehicle I take off-road is my Jeep Rubicon that has dual locking axles, several chassis frame mounted tow hooks and receiver hitch with shackle, towing straps, a ****** block and a 12,000 lb Warn winch. Even with this equipment, I like being with a group of similarly equipped vehicles.
