Homelink not working consistently...
Any tips and tricks would be greatly appreciated. I have only followed the instructions in the manual.
See https://en.m.wikipedia.org/wiki/Rolling_code
HomeLink Customer Service is based here in the US - and they are very helpful and thorough in walking you thru to a solution.
You might consider before the call "erasing" the settings in your MB - with car on - press both "outside buttons" (#1 and #3) simultaneously - hold both for about 1min (which seems like a long/long time) under the indicator light changes color.
HomeLink is very helpful..
after several days of chewing nails, it figured out I made a mistake. I pressed the programming button on the opener, then held the button in the car while holding the opener’s remote. And it worked. BUT... I forgot to press the car’s opener button a couple more times to open and close the door.
Once I actually completed the WHOLE procedure, it has worked perfectly for the last eight weeks.
Don’t know if that’s your issue
