Trailer and offroad package questions
Also I was trying to figure out how well either can do in snow. My road tends to not get plowed at times. I had had an E class wagon and it did slip on my steep driveway many times when going down it. The Audi quattro system did better on that. But I saw videos where there was not just an offroad drive select setting but the person was specifying sand, trail, etc. So what packages get you offroad drive select option and even the ability to specify sand, trail, slippery. And do you find the features helpful?
Thanks.
Downhill slipping is an ABS task, not a traction task. There is a practical limit of tire contact patch weight, friction (ice) and grade. All vehicles will slip downhill if the combination those factors adds up the wrong way. It’s a mu * N thing.
4ETS and ABS will help with the slippery downhill situation. There is no 100% certainty that a given vehicle will succeed in all conditions. When in doubt, salt, plowing and weight in the vehicle (salt or sand bags) improve the odds a bit. As will getting two tires off the slippy driving surface and onto the shoulder with gravel, soil, sticks, etc.
Thanks.
Thanks!
MB 4MATIC systems are truly underappreciated in my view, because they are extremely capable in the base version, and near Jeep-class with the off-road engineering package.
Again no one in their right mind buys a GLS to take on the Rubicon.
And then the other question about the offroad package was not if they would be really great off road vehicles meant to get in all of the places. But it was more about another review I saw the person had options to say it was on Sand, Trail, Slippery. I was curious if that was a feature that came with AIRMATIC or if that was only a feature if you had the OffRoad package. So I'm unclear what drive select settings are on standard suspension (if say GLE does not have air suspension), with air suspension, and then how those options change if you get the off-road package or the E Active Body Control package.
Basically I saw another review (this time US based but it was an AMG) where the guy was driving on packed snow roads and he was using the different settings of Sand, Trail, etc. Inventory is not that great for me to look at in person at this time so I'm trying to figure out what you get stock and what packages add what features.
It is great to hear how people feel their vehicles handle the conditions, towing, etc so thanks for the information.
I did have a 2011 ML350 and it also would slide on my driveway. I get the previous point of load the rear to help and yes you need to shovel, salt, etc. My problems were more when I was already out at work and kids at school and was coming home to the bad conditions. Maybe the 3rd row weight on the Audi Q7 helped as I would go down the steep driveway slope or the hills in my community fine without sliding in the Q7. So I'm thinking that 3rd row weight in the back did help. And yes I was crawling slowly trying to leave space for braking or going slow at certain downhill curves, etc.
But if anyone knows what drive select settings you get with and without air suspension and what then gives you the option to specify you are driving on Sand, Trail, etc. I think that would help me decide what features/packages I wanted to order.
I do think that Trailer Maneuvering Assist package that will help steer maybe is not available in the US at this time. I just liked that feature I saw since I do not tow frequent enough to always be efficient at it.
Towing on the other hand, GL/GLS is in a different class. In my experience, GL is very stable, pulls strongly, has fantastic brakes, and good cooling system. Its heavy and has a relatively long wheelbase, both good for towing. I'd rate it as the best unibody tow vehicle in the market today. I also believe that for heavy (and regular) towing, a lowly half ton pickup is more practical that GL/GLS.
"Please don't forget with GLS Dynamic Select - Your will Have Sport, Comfort, Slippery, and Indiv setting - and yes, for NE Slippery will come in handy."
But maybe 2020 forward they got rid of the Slippery setting and now have Offroad but only if you have a certain model (AMG) or certain package maybe only then can you customize what offroad setting you are in?
Basically I've now found 2 GLS AMG videos that mention sand and trail offroad setting but I do not think a stock GLS450 has ability to set if the offroad mode is sand, trail, etc. One video, 2020 GLS AMG63 Snow/Ice review, actually shows the Sand, Trail, etc but it was while he was driving vs an overview of the settings. Originally I was assuming it was some sort of off road package or something. So does anyone know if the off road package also gives you the ability to specify the offroad mode?
I am having a harder time finding the GLE information and not as many things are available on the GLE. I am torn between the GLE and the GLS. I only use the 3rd row actually for my larger dog to have a dedicated seat when we go on family road trips and the 2nd dog is smaller and easier to find her a safe spot.
https://www.mbusa.com/content/dam/mb...E%20SUV_OM.pdf
Again I have to find inventory to personally check out the different engines still myself even if they do not have certain features added. So I was trying to maybe clarify it better if I can't find both engines.
Thanks for all the information so far.
Traction control in the most general sense is accomplished by throttle position map adjustment, which modifies power and torque delivered to the transmission. Transmission gear selection map is modified to deliver torque to suit the driving conditions. The braking system uses ESP/ABS/4ETS to stop wheel spin, if throttle and gear selection results in torque that exceeds the traction available at the wheel. These functions are contained within the base 4MATIC system and do not require the off road package. Mercedes delivers a highly capable 4MATIC system. The off road package is even higher capability, approaching 4Runner and Jeep levels of performance.
Vehicle attitude (steep incline or side-to-side tilt) is detected automatically via suspension height sensors and LED headlamp positions are adjusted to compensate.
This Is the U.S. Army's Official Humvee Replacement (roadandtrack.com)
Google “G-Wagen Black Bear Pass”. Lots of Gs are used in aggressive driving situations. I’m from the eastern US where off roading means narrow lanes with paint-scratching tree branches in the driving path. Out west (CO, UT, AZ) this has not been my experience with wide open driving routes, for the most part, although far steeper, rockier and more difficult than the beautiful green and dark, muddy routes in the east (MI, PA, VA, NC).
BTW I dont think that the trailer parking control is available in the US. I haven't trailered anything yet so Im not entirely sure on that.
