Winter tire
Nice. Can you share where you got the wheels/tires? And if the aftermarket TPMS just worked out of the box? And did you swap it yourself - i am interested to know if you use any speical jackpad or the general MB one just worked.
I am still waiting for my wheel/tires shipment. The place that i bought from (ExtremeCustoms) ordered a 30MM lug bolt for me.
- THREAD PITCH 14X1.5 BOLT
- RHI 14x1.5 Lug Bolt (30mm) Spline 5 Lug Kit - Black
Correct, I used M15x1.25 Lug Bolts Ball Seat for these wheels, I bought both 28 and 33mm, and 28 looked best, 30mm would work but not in the size the OP suggested.
Correct, I used M15x1.25 Lug Bolts Ball Seat for these wheels, purchased off Amazon. I bought both 28 and 33mm, and 28 looked best, 30mm would work but not in the size the OP suggested.
thanks
the 2nd photo is both the mb lug nut and the black nut I received, on the new 22” mandrus estate wheel pushing in all the way. It looks like the black on is too short.
i installed it anyway but I worry if it too shorts will it cause issues ?
thanks
- Mandrus Estate 22x9.5 with +40 offset.
- Conti VikingContact 22" tires
- M15 x 1.25 28mm lugs
- 111 lb torque.
- Convex socket from Amazon to take off my OEM lugs.
