GLS Class (X167) Produced 2020 to present
TRUNK WONT CLOSE ALL THE WAY
Old Nov 29, 2021 | 12:52 AM
CuriousGuy198's Avatar
GLS450
Today some weird stuff happened . So my trunk suddenly wont close with red button on the trunk or inside driver side button.
it will start closing and somewhere mid way it will make a sound like it bump something and starts opening again.
i checked - nothing is in the way , then eventually since i was in the parking lot far from home i gave a little push on that level where trunk starts opening again , and with my pressure it went through that point and closed .
Tried once more at home - same problem.
Any ideas what could cause it and how to fix it ..?
Old Nov 29, 2021 | 03:34 PM
Paxfobiscum's Avatar
Chevrolet Chevette, Ford Pinto, Pontiac Aztek, Trabant, Yugo GV (and all the worst cars ever built)
Your dealer should easily diagnose this.
Old Nov 29, 2021 | 04:24 PM
GLS450
Yeah but any ideas what could it be ? Before i go to dealer ?
Old Nov 29, 2021 | 04:28 PM
The door is sensitive and any blockage will cause it to stop. It probably needs cleaning or the hydraulic (??) needs lubrication.
I have that problem sometimes but rarely.
Old Nov 30, 2021 | 08:15 AM
GLS450
Thank you , yeah i tried lubricating them , seems helped , started moving way more smoothly, even closed couple times , but then start doing it again. Now needed way less pressure to close it , but still probably needs cleaning , i guess ill give a visit to a dealer.
