I'm pretty lost.
I have been dealing with a noise issue in my 2024 GLS for months. It's a low-pitch clunk/rumble coming from the back of the cabin that is most noticeable when driving slowly and going over a small bump or pothole. If I go faster or rev up the engine (or radio is on), it is masked by the road noise and can no longer be heard. You normally hear a bump as the wheels go over the road imperfections, but in my car, there seems to be an extra bump noise coming from the rear, as if there are loose panels bouncing once or twice more. I emptied out everything (even the spare tire) and the noise remained.
At the dealership, a senior tech drove with me and was able to hear the noise, so at least it seems I wasn't hallucinating. According to the SA, they were able to isolate the noise to "stowage tray cover" (the cover piece over the spare tire compartment) and applied some felt tape here and there and eventually replaced a part (I assumed it was the same cover, but the SA said it was something else that was loose). The noise was somewhat reduced, but I could still hear it (sometimes more noticeable, sometimes less, but it was definitely still there). Of note, during the visits for the noise and other service visits in the past few months, I drove quite a few different loaners (GLC, GLB, GLE, EQB and EQS) and never heard a similar noise from any of those cars.
Frustrated, I made another visit today to have the dealership look into the noise again. This time, they gave me a 2024 GLS as the loaner, and as I was driving away from the dealership, I heard THE EXACT SAME NOISE IN THE LOANER CAR!
I am totally lost and confused here. How likely is it that two different cars are having the exact same defect causing the noise? If two 2024 GLSs are making the exact same noise (that I couldn't hear in a handful of other MB SUV models), could it be just a "feature" rather than a problem? Have I been too demanding and nitpicking? (I felt a bit embarrassed to be honest...)
Please help me out here next time you take your GLS for a ride, listen carefully with radio off while driving/coasting slowly and see if you can also hear what I hear when going over small road bumps. Thank you!!
I don't hear any noise but I have a MY23, right before the MY24 refresh. That would stink if this is common to all MY24 and continues to exist the entire generation through to MY25.
I know your dealer looked at it but I would double check to make sure all ties in the spare tire area are tight and that you don't have any loose tools or AirTag bouncing around!
I'm pretty lost.
It took me a very long time to isolate the location for the exact same noise coming from my 2020 GLS in exactly the same location (except mine does not have a spare) but it's the same cover mechanism over the compartment below. I had brought my car in twice to have it checked out at the dealership. Each time they claimed to have driven it for a couple of hours and didn't hear it. I found it nearly by accident by crawling around the cargo area and taking everything out of it and examining it carefully. Finally I realized it was the deck cover that was making the noise, maybe a hinge. I haven't brought it to MB to address it yet, so I can't offer any solutions yet, but only empathy b/c I know what you've been through.
I'm pretty lost.
Try folding down the rear seats (both rows) and see if the noise changes. The seat backs could be loose in the latches.
Yes, we've checked that. I completely emptied that area and removed the spare (btw good exercise to get ready for the day you need to use that spare!) and the noise remained.
Thanks for the empathy and sharing your experience. I think that's what the dealership initially thought in my case as well. However, that deck cover can be easily removed (there are 2 hinges with 2 hex bolts on each) and unfortunately the noise didn't go away when I removed mine.
Thanks! That's also one of the things I thought about. I tried it with all seats up, all seats down and various combinations in-between and didn't feel much difference in the noise.
After ruling out most other sources, I started to suspect that the noise was coming from the hatch/liftgate. I sat inside and closed the liftgate and as I banged my fist on it from inside, I could almost hear that extra bounce as if something was loose inside. The SA called me today and said they also found a loose latch (?) in the liftgate and they think that was the source of the noise and they fixed it. I will pick up the car tomorrow and will report back.
Picked up the car today and the noise is gone! Guess third time was the charm! The cause: loose tailgate lock assembly (see below). Considering that I heard the exact same noise in the loaner GLS, it might be a prevalent assembly issue so check your cars at low speeds to see if you hear the extra bounce.
Thanks for the update, and seems like a good job by the tech to be thorough and track down the noise...
That seems like a really detailed and helpful write up of the issue too. I have never seen that kind of attention to detail from a mechanic when writing up an issue resolution.
I don't have the noise in mine, but thankfully it sounds like an easy fix if it starts bumping.
I'm pretty lost.
I have the same exact problem with my 2024 GLS 450 as well. I can feel every small bump and creaking sounds when I go over them at low speeds. It’s pretty annoying for a car that costs 100k and is thr flagship of MB SUVs. Did anyone find a way to reduce the noises.
Great title for a thread. Especially when Christmas is nigh. When it sneaks up on you, it’s a silent nigh.
Maybe I can tie that into a new thread title.
2021 GLS 450. Have a Holden Commodore, Jeep, truck, and more
Glad it's resolved. Many years ago I worked at a dealership (not MB) and spent a large part of my time doing "trim" and interior. Much of that was spent chasing noises and resolving them. It can be really tough, but a good tech can usually solve it. Sounds like you had a good tech.
Thank you for sharing.
Typically to get paid extra diagnosis time (which it appears by the desciption) you have to write up a thorough explanation of the diagnosis and resolution. Especially if it is a return visit.
Great comment.
The better the customer's description, the more likely the problem can be found and fixed.
Especially with squeaks and rattles.
Originally Posted by mikapen
Great comment.
Definitely! This is also where a good service writer is important. When I worked in service many years ago we would play a game of making up problem descriptions based on the service writer. Some were horrible. IE "hears funny noise" vs "Hears metallic noise in right front area when going over expansion joints at high speeds, but doesn't feel anything in the steering wheel or chassis"
When your service writer hands you the service order to sign off at dropoff pay attention to what they have noted. Also look at the invoice when you pick it up to see what is written there. Often times this is the difference in a proper diagnosis/repair and getting told it's normal.
That's a definite yes! Make sure the description matches your problem.
I write my own brief description and make sure it's attached to the RO. The technicians appreciate it, as does the Service Writer, if you handle it tactfully.
