GLS Class (X167) Produced 2020 to present
AC Problems
Old Apr 30, 2024 | 03:23 PM
Scott Schmidt's Avatar
GLS 450 (2022), EQE SUV 350 (2025). GLS 450 (2007)
AC Problems
Hi Folks. I'm driving across the country in my 2022 GLS 450 and yesterday I drove from St. Louis to Atlanta. Unfortunately, along the way I could not get my AC to put out any cold air. I mean it was hotter in the car than outside. No matter how I set the HVAC switches, no cold air would come out. I restarted the car a few times and that didn't help. Needless to say it was a hot and loud drive as we drove 600 miles with the windows partly open.
So I made an appointment with the local MB dealer here in Atlanta, and of course when I started the car this AM to drive it there the AC worked just fine! The dealer also ran checks on the AC and reports that nothing was wrong. Can anyone shed some light on what the problem might be? I swear that I had the AC switches set correctly and this is not operator error!! Thanks for any advice.
Old Apr 30, 2024 | 09:11 PM
LeadfootCJ7's Avatar
2021 GLS 450 & 23 GLS 450. Have a Holden Commodore, Jeep, truck, and more
Verify the rear seat settings. I had a similar situation and it was because somehow the 3rd row was set to 60 or low and was demanding all of the cold air. Apparently the AC is set to prioritize the rear to keep temp. Seems odd. The service writer mentioned to me that sometimes the "case" goes bad. When I pried to find out if he meant blend doors or something else and he just said they have to replace the entire case because it goes bad. I hope they can get it resolved for you, Mine has never done it again so I cannot say for certain mine is "fixed"
Old May 1, 2024 | 01:01 AM
wildta's Avatar
GLE 580
Definitely check your other vents to see if cold air is blowing elsewhere, if so it's a stuck blend door actuator.
Old May 1, 2024 | 07:37 AM
EWL5's Avatar
'23 GLS450
"Sync temp" is your friend! Be thankful it's still a physical button....for now!
Old May 1, 2024 | 10:44 AM
wildta's Avatar
GLE 580
No kidding, BMW X5 and RR just removed them in 2024 models.
Old May 1, 2024 | 01:29 PM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Yes, this. Literally discovered it after driving our GLS home from the dealer with the air blowing full but not getting cooler. Front was calling for 70 and the rear for 78.
Old Jun 16, 2025 | 09:01 AM
Jhc14's Avatar
GLE450
Did you get a resolution to you
we have the same problem did you get a resolution?
Old Jun 16, 2025 | 09:07 AM
Nothing was done to make any repairs and the issue has never returned. I think that maybe the rear temp was set very high due to inadvertent contact with the buttons, and this was the sole (silly) cause.
Old Jun 16, 2025 | 02:05 PM
mikapen's Avatar
Well, that'll do it!
Thanks for responding.
