GLS Class (X167) Produced 2020 to present
Check engine
Old Aug 7, 2024 | 09:24 AM
shortleg's Avatar
Current: GLS 350d - X167, E 250 CDI 4Matic W212, Past: E 280 CDI - MB211K
Check engine
Hi all,
I have a check engine light on (amber/yellow).
I have not noticed any issues with the car.
I tried contacting MB dealers but they are all super busy (long wait).
Is there a way to get some info about the problem from dashboard or phone apps?
The car has cell connection service … why can’t MB or me customer get info remotely about the issue ?
I am planning a 1300 miles drive and would prefer to know before hand if this is something that might show up as bigger problem when doing that amount of miles.
TIA
Michelangelo
Old Aug 7, 2024 | 09:27 AM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
Solid light is FAR better than a flashing light. That said, most any autoparts store will be able to tell you what the codes are and go from there. For a solid light in general a typical OBDC scanner will get you going for the time being.
Old Aug 7, 2024 | 09:34 AM
shortleg's Avatar
Yes the light is solid …
I am in Italy, Milano. This city closes for holidays on august , and the few that stay open are fully booked.
I already tried an auto parts store, they are also booked.
That is why I started wandering if it was possible to find out about the issue from the dashboard.
Old Aug 7, 2024 | 10:33 AM
EWL5's Avatar
'23 GLS450
OldManAndHisCar has given you the best advice. Seems like you're stuck unless you buy your own OBDC scanner.
Old Aug 7, 2024 | 04:09 PM
mikapen's Avatar
I should probably get a scanner. I'm going off warranty next spring, and I'm moving away from my trusted dealer.
I haven't seen any recommendations recently from forum members as to which ones are the most cost effective for Mercedes these days.
Do you have any insight?
Old Aug 7, 2024 | 04:56 PM
EWL5's Avatar
'23 GLS450
I don't personally own one but when I was considering them, I checked Amazon and SlickDeal reviews.
I'm sure others can chime in!
Old Aug 7, 2024 | 05:06 PM
wildta's Avatar
GLE 580
The Launch Creader is lauded by many forum members: https://www.amazon.it/s?k=mercedes+o...ref=nb_sb_noss
Old Aug 8, 2024 | 08:57 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
I have an Autel handheld from 2017 that read all the W164 codes just fine and even gave some live data. I tried a couple of the tablet based ones this spring and they were pretty similar for functionality against each other and with my older tool. They all appear to run Android 10 or 11 and I suspect they are all using the same android app and database for codes and functionality so the brand is less important. Some of the manufacturers like Launch put a flashier interface but most of the mechanics I see are using Autel. I have also seen one recomend the XTool line. The bluetooth ones are convenient but will be slower than cabled ones.
Personally I sent them back and got a full Xentry system put together to use but it's likely overkill for most people.
