GLS Class (X167) Produced 2020 to present
Warning light meaning ?
Old Feb 27, 2026 | 08:03 PM
lungs414's Avatar
2024 GLS 580
I see this when I start it but don’t see it while driving. Active assist  I think. Does this mean there is a problem ?
Old Feb 27, 2026 | 09:18 PM
mikapen's Avatar
Depending on when you see it, it's probably a system check showing you that the light works.
Old Feb 27, 2026 | 09:55 PM
lungs414's Avatar
2024 GLS 580
Thanks for the response. But it seems weird that it’s the only light on. I may go down to the dealer and see if I can ask them.
Old Feb 27, 2026 | 10:23 PM
superswiss's Avatar
2019 C63CS
Forward collision warning and emergency brake assist is off when you see this. Actually in your case I think it's indicating a malfunction. If the word Off is also displayed above it, then it was deliberately turned off, but without that I'm pretty sure it means malfunction.
Yep, here's what I see if I turn off ESP in my car, which then also turns off the forward collision system. Notice that it says Off in addition to the symbol you are seeing.
Old Feb 27, 2026 | 11:38 PM
lungs414's Avatar
2024 GLS 580
Yeah no "X" or word off. I wonder if it's a dirty sensor. We had crazy snow around here for the last week. I will check that first.
Old Feb 27, 2026 | 11:54 PM
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Definitely clean the sensor first
Old Feb 28, 2026 | 11:09 AM
EWL5's Avatar
'23 GLS450
+3
Old Mar 2, 2026 | 09:59 AM
jkaetz's Avatar
2021 GLS580 | 2011 ML350 BlueTec | 2009 Pontiac G8 GXP
Depending on options, it could be the cameras by the rear view mirror being obstructed or confused as well.
Old Mar 2, 2026 | 08:05 PM
lungs414's Avatar
2024 GLS 580
Haven't been home to see about cleaning it.
