W210 E300 Kills a R230 SL500
1 Post
Tesla Roadster Sport
I was on a 30 degree uphill incline waiting at a signal light, when a R230 SL500 pulls up. He pulls slightly ahead of me into the crosswalk, and was "braking against the tq convertor" while waiting at the signal light. The light turns green, I floor my E300 a big plume of black smoke comes out of the tailpipe, at this time I could physically hear the SL's motor working overtime, it was real loud, he was obviously flooring his vehicle as well. By the time I was at the top of the hill I was 3 Car lengths ahead. I tried slowing down so that he would pull up and we could go at it again, but he kept his distance, he was obviously embarassed that his so called "sports car" got owned by a plebian diesel car.
Specs on My Car:
Speedtuning Chip Level 2 Chip
AFE Air Filter
Specs on My Car:
AFE Air Filter
Specs on My Car:
AFE Air Filter
Specs on My Car:
AFE Air Filter
i dont know about this one....
mark
95 Audi urS6 Quattro
mark
mark
2002 E55 AMG
With your mods your W210 E300TD has more power than my W210 E320! But diesels run out of steam at higher speeds...
Isn't the W211 E320CDI quite a bit faster 0-60 compared to an E320? I remember seeing the stats and the E320 catches up and passes at higher speeds. But you have to love the low end torque!
2 SL with every Brabus mods available & Class A competition sound system
No......way in hell you kill an SL.....
SL 0-60 in 6.1 sec.......
E300 turbo diesel 0-60 in 8.5 sec
Ok your car is modded....... No way your car can knock off 2.4 sec....... you say you beat by 3 Car lengths which mean your car got to knock of at least 3 sec to beat an SL.....
just my 2 cent........
![Nonono](https://mbworld.org/forums/images/smilies/nonono2.gif)
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
just my 2 cent........![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
mighty fine .02 my good man..
mark
SL driver wasn't going for it, and he didn't line up again because he didn't care to see another puff of diesel smoke.
The SL's have a strong launch, more torque, ESP and wider tires. It would not have lost off the line.
An E300 may take an E320 off the line, but keep in mind neither of them can take the SL. I've raced both an E320 and an SL500. The difference in their launch is huge.
He was def flooring it I could hear his motor laboring
1 Post
mongoose,
if you dont believe me, i live in the nxt city over from you...drive my car and see if I am bsing. He was flooring it I heard it stay in first then shift, he was def trying to race
SL/M6
Youre most likely wrong....just because tou "heard" him flooring it gives no reason to justify relevant evidence that he was infact pushing his car to the max. My SL sounds like I'm flooring it even if I'm just messing around with the wheel shifters or if I push the pedal a little bit at the launch...I'd bet you $1,000 that in a real full out launch to 100, at any angle of ground, you would be toast. Plus I have the 7 speed
mongoose,
hey, if we ever cross paths, id love to run with you.
my licence on my SL is MARK CH.
and on my E500 is E5hndrd
Originally Posted by 360_iti
SL500 has 302 hp & 339 lbs/ft with 4,065 lbs.. not the greatest power/weight ratio. The W210 might have a better ratio.
This is the fact:
E 300
Curb weight 3,640 lb
Net power 174 hp (21 pound per hp)
Net torque 244 lb-ft (15 pound per tq)
SL 500
Curb weight 4,065 lb
Net power 302 hp (13.4 pound per hp)
Net torque 339 lb-ft (12 pound per tq)
W203, W211, W219, W212
You're right. Even with 228 hp like what he stated, the W210 still doesnt have a better ratio. AltrhiTheir torque ratios are about the same.. 315 lb-ft on 3640 lbs.
1 Post
If you are calling me a liar, you are sadly mistaken....put your money where your mouth is...if you have a sl500 lets race on an incline and see what happens.
