Kill Stories Discuss your exciting high speed excursions here!
The Battle Of The 6 Banger Family Sedans
Old Mar 15, 2007 | 06:16 AM
turbo kraut's Avatar
2001 A4 1.8tQMS
Originally Posted by AndrewAZ
Going from 13's to 14's to 15's is a big difference.. Both the audi and the E350 have just about the same horsepower and weight.. We did rolling starts and if his car was faster then he should of pulled away but it was the other way around I walked away from him even when he got a jump.
Anyways a while back Eric (E1000) and I went to the strip. My best run was a 15.03 @ 93.3 mph but of course that was because of ESP being stupid along with not getting traction off the start. Car and Driver says it should run a 14.6 @96 mph. Plus I had more than 1/2 a tank of gas.
i am not doubting you beat your boy, i am doubting his driving skill
does he have a boost guage? is he deaf?
the reason i say both, is cause he is bi-turbo and should of smoked you like a joint...... he should of spooled his turbo's and with quattro his launch would of gotten him an easy car car 1/2 jump on you, then maybe once you caught up, if you could of, then you guys would of been neck and neck
it is like me running my buddy with an identical a4... he is a 00 so that means from the factory i get 20 more hp....woopty do right? i smoked him cause of driver skill and turbo spool
Old Mar 15, 2007 | 06:39 PM
AndrewAZ's Avatar
BMW FTW
Look up the stats for the audi A2.7T its not that fast of a car(Your keep talking about the A4 which is almost 1k lbs less which makes a heck of a difference). It has less HP and weighs the same as the E350. It is also rated the same 0-60 time as the E350. We didnt go from a dig we went from a roll and I would floor it and walk him a bit then let off and he would get back even going WOT then I would got WOT then walk him again. I might see him on friday night and I will take my BMW and run him cuse he probably wont want to race the benz again cuse he came talking **** about how he was going to smoke it but after the races he just LOL and was like BS that thing does not have a V6 in it.
Old Mar 16, 2007 | 05:34 PM
2001 A4 1.8tQMS
you are correct about weight....... so run him from a dig, see who wins
Old Mar 17, 2007 | 02:48 AM
AndrewAZ's Avatar
BMW FTW
From a dig he will be even worse off(weight of 4wd along with turbo lag.. He did his run on the same track a week earlier and was doing low 16's in the 1/4 mile.. I was doing almost 15 flat run after run with more than half a tank of gas an ESP along with traction problems off the line. I think you are thinking of a chiped A6 2.7t that would certainly run mid 14's to possible 13's since it basically turns up the boost from factory 6-8psi to 18psi and effectively makes the stock cars BHP the WHP big difference in a car that is putting 260 to the wheels then putting 200 to the wheels, putting 260 to the wheels is M3 territory.
Old Mar 19, 2007 | 07:31 AM
itsmeek's Avatar
Nissan GT-R cobb/midpipe/ic piping/wastegate actuators/tials
are you joking here? so since he has turbo's and awd he should win the race? you forget that the kings of drag are still the rwd's. and weight plays a huge factor along w/drivetrain loss on those 2.7tt's. no offense but.. you drive a 1.8t, that car is slow as *****- unless you spend over 8k on it. and spooling a turbo that is that small doesnt do much for u since it will run out of gas right after the launch. not to mention his car is an auto so "spoolin" from a stop and letting go of the brake will most likely kill his drivetrain very very quickly.
Old Mar 19, 2007 | 01:51 PM
amgdriven's Avatar
w210 E55
I like kraut. It tastes good on a rueben sandwich.
Most of your pointless posts are glorifying your a4 and questioning everyone else’s ride. Have you tried an a4 forum? Rumor has it, they actually like that car over there on those forums.
