Destroyed a new Audi S8 Wagon & an new M6 Vert
#51
Audi S4 Avant and BMW X5 4.4
I think my 550 HP S4 can/will hold its own against even a "Kleeman" SLK55.......actually, I KNOW it would.
BTW.....why do you refer to "A4 Avant" or RS4 "A4" with V8? It's an S4.....and it's an RS4....try getting it straight if you are gonna talk cars. And yes, the V8 RS4 is SLOOOOOOW......what is your point there?
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
i'm still flabbergasted on why you use 0-60 or 62 times.....as anyone know they don't mean much in the whole context of comparing cars from a roll (which usually measures the cars power). But since you are using it.....I highly doubt an Kleeman SLK55 can do a faster 0-62 than a Stage 3 S4. Why? First of all.....TRACTION. A "489 REAR WHP" SLK with its lighter weight will SURELY spin its tires off the line. Compare that to a 430-440 All-WHEEL HP Stage 3 S4 with 450 Wheel TORQUE.....will have MUCH more traction than the RWD SLK. So if you are comparing 0-62's (0-100 KM).....an S4 with that power and AWD Launch will outaccelerate a RWD SLK because of traction. As far as being faster than Enzos.....I have data (via APR's ECUx datalogging) of Stage 3 S4's able to do 0-60 in 3.2-3.2 seconds. AWD Launch, 450+ wheel Torque at 3k rpms.....it adds up. Either way.....I don't put much emphasis on 0-60's (even if it is an advantage with AWD Quattro on the Audis). I rather put more emphasis on TrapSpeeds in the 1/4 mile of a car. What does a Renntech SC SLK55 trap? I know Stage 3 S4's usually trap in the 118-122 MPH range. I know Renntech SC C55's trap 116-117.....so I'm guessing a little higher on an SLK55?
#52
#54
2011 E-class coupe, 2012 C-class
hehe.. Im not that much into Audi. A friend of mine has the new S3 and I am also concidering to get one, I think its a nice small car that I can have lots of fun with. Anyway lets keep it to 0-62 time and 0-62Mph in 3.7sec is very impressive for a small car like the Kleemann SLK. I think the SLK would be faster as it has 596HP and its probably lighter than your Audi. In other words what your telling us here is that your Audi is faster from 0-62 than the 660HP 3.65sec Enzo?? I find that hard to believe. ![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
The 0-62MpH or 0-100km/h times are used by all car manufactures to give people an idea of how fast the car is and this is also what I’m referring to here. In urban areas all one does is to race from one traffic signal to the next, hence the validity and justification of the 0-62 times. The 0-62 time is documented on the Kleemann SLK 55K S8 and all traction problems are also included in the 3.7sec. In other words when you put down the pedal in the SLK, the 7 shift transmission will transfer the power easily to the rear wheels and 0-62MpH will be over in 3.7sec. See link below:
http://www.emercedesbenz.com/Jul06/1...LK_55K_S8.html
I must say that your car must be very fast as it takes out any Enzo, Gallardo, SLR and its only 0.7 sec from the Bugatti Veyron.. Forget about the 1/4mile disciplines, I think you should do a plain 0-62MpH test of your car, perhaps you have overestimated your timing
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
Btw your S4 is probably a 2.7L US-version = 250HP 0-100 in 5,9sec, if you take a look at some of the serious German VAG Group/Audi tuners like Oettinger, the maximum stage 3 output on your car would be 420HP and a 0-100 time in about 4.6sec, even with your undocumented almost 500HP it would be a impossible task. So in other words I am quite sure that your S4 will never do a 0-100km/h or 0-62MpH in less than 4 sec, unless you fit a rocket in the backend. Try to be more realistic next time you post your accelleration values
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
And Yes the Kleemann SLK will eat any Ingolstadt Audi any day
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
#55
I guess Mr. EvilEmpire chickened out, The (MB) Force will always defeat the Dark Side.. HAHA
S4 0-62MpH in 3 sec is just absurd
#56
Another tidbit: http://forums.audiworld.com/s4/msgs/2114075.phtml
And you can pretty much calculate 0-60 times from 1/8 and your 60 foot. A 1.75 60 foot is usually 3.7-3.8 seconds in the 0-60. A 1.6ish 60 Foot....and you are looking at lo to mid 3's in the 0-60 (3.2-3.5 second range). Here is a database of Stage 3 S4's and what they have ran in the 1/4 mile, you can click on their slips and see their estimated 0-60 times. Most of them are in the 1.6-1.8 60 foot range, so that would eqaute to a 0-60 of anywhere from 3.2 seconds to 3.9 seconds.
http://www.s4biturbo.com/timeslips.cgi
I have seen data not just from 1/8 time and 60 foots of 3.2-3.4 seconds in the 0-60, but also from ECUx data logs from a couple of Stage 3 S4's. That would take a perfect launch/very very good driver....but the point is, it is possible. But to answer you 0-60 times question, the Average Stage 3 S4 will do 0-60 in anywhere as quick as 3.2 seconds....to 4.0/4.1 seconds. All depending on how hard you wanna take off. The norm is not lo 3 second range (more so hi 3's to very lo 4's)....but it is doable, and the ability of a Stage 3 S4 to do it is there.
So before you call someone out and "chickened out" on a board......try doing yourself some research on the Car you are questioning instead of talking out of you *ss
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
![slap](https://mbworld.org/forums/images/smilies/slap.gif)
PS. I will find you the data on that lo 3 second 0-60, it is buried somewhere in AW
#57
Btw your S4 is probably a 2.7L US-version = 250HP 0-100 in 5,9sec, if you take a look at some of the serious German VAG Group/Audi tuners like Oettinger, the maximum stage 3 output on your car would be 420HP and a 0-100 time in about 4.6sec, even with your undocumented almost 500HP it would be a impossible task. So in other words I am quite sure that your S4 will never do a 0-100km/h or 0-62MpH in less than 4 sec, unless you fit a rocket in the backend. Try to be more realistic next time you post your accelleration values ![bs](https://mbworld.org/forums/images/smilies/bs.gif)
![](http://www.awe-tuning.com/media/products/awe/rsk04/awe_rsk04_dynosheet_crank.jpg)
Here is more info on the kit:
AWE Stage 3 Kit
This is just one of the tuners....others such as Autospeed are even more powerful right out of the box than the AWE kit.
Again....this is no knock on Euro Tuners....as I am sure they do a fine job with their kits for the Audi BiTurbo S4. But American Tuners like (AWE, Autospeed, and APR) have surpassed them in power output and still providing a stocklike driveability. Listen....again, try to do some good research before you start talking about things you don't know. I kep it civil until you started posting these "chickening" out posts and BS data from Oettinger (newflash, OETTINGER doesn't EVEN OFFER a Stge 3 kit, they are not a tuner (software wise)....they offer wheels, body kits, exhausts. But again.....you were talking about something you have no idea about, so I'll give you a pass on that
PS. Stage 3 S4's will still do 0-60's in 4 seconds OR LESS......but like I said, 0-60 is meaningless. Trapspeeds telltale of a cars power...not 0-60. Hell, a 280 HP EVO can do a lo to mid 4 second 0-60, but in no way it gonna keep up with cars like an E55 AMG (which does similar 0-60 times) on the highway. Obviously because an E55 has close to 500 HP and EVO not even 300....but they are very close/even in 0-60 times!!! LOL
#58
#59
LOL Empire strikes back
I like this
hehe.. thought you were long gone
I guess you must hate the 0-62, your values sound like guesswork to me, its all theoretical. Btw did you do a 0-62Mph on your own S4? Just for fun try it and tell us how long it takes.. ML is no racer, its a cruiser -Soprano style
#60
I like this
I guess you must hate the 0-62, your values sound like guesswork to me, its all theoretical. Btw did you do a 0-62Mph on your own S4? Just for fun try it and tell us how long it takes.. ML is no racer, its a cruiser -Soprano style ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
BTW.....what do you think of the Renntech SC C55 (400+ whp...so close to 500 HP)? Might not be as quick 0-60 as the 3.7 of the SLK
#61
Actually, it is 3.8 seconds 0-60...
...at least the one C&D tested was, anyway. Only test I've seen for one:
http://www.caranddriver.com/specialt...mann-55s8.html
Zero to 60 mph: 3.8 sec
Zero to 100 mph: 8.9 sec
Zero to 130 mph: 15.2 sec
Street start, 5-60 mph: 3.9 sec
Standing 1/4-mile: 12.2 sec @ 117 mph
Top speed (redline limited): 187 mph
Braking, 70-0 mph: 160 ft
Roadholding, 300-ft-dia skidpad: 0.90 g
Kleemann claims this car is putting out 570 hp. Weighing 3800 pounds and trapping at only 117, not quite; it calculates out to about 500 crank. It'd be trapping at 122+ with a true 570...
#62
PS. I will hopefully be doing runs with a Kleeman SC C55 soon.....he is actually a really cool car enthusiast and a member of this board as well. It should be alot of fun
#63
just saw on an earlier reply to this post on page 1......a stock SLK55 weights 3350 lbs. Any way to do the calculation on that.....say that the Kleeman Kit makes 500-525 hp range? I am guessing anywhere from 120-123 range?
#64
#65
sure....just take my 1.8 60 foot and my trap of 90 mph in the 1/8 and I am sure you can figure it out "Mathematically"......which is much more precise way (other than maybe say a Driftbox GPS system). Other than that.....like I said, i am not too worried about 0-60 times. My car more than holds its own vs other cars (C6 Z06, 997TT's, etc amongst others). I know what my "Audi Avant" from Ingoldstadt can and cannot do.
but I am sure it still is in the lo 4 second range. Do you think that car will "smoke me" too? A legit question![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
#66
that is very good info......good stuff Improviz
Now if Kleeman rates their kit at 570 HP, but it is closer to the 500 HP number according to TrapSpeed calculations......would you say Kleeman is overrating their SC kit for the N/A 55's? Just a thought.....not trying to start a tuner war or anything.
If so.....since we know Kleeman SC C55's trap about 116-117 (and that is best conditions).....the SLK55 Kleeman should be in the "similar" if not identical HP range. Say that it is, if the C55 traps 116-117 (which i said in post/reply #51).....the lighter SLK55 would trap say 5 MPH faster, if that? (not sure on the weight of the SLK55)
But anyways...are there any numbers for what the SLK would do? If you could calculate what the weight + HP (500 or so HP) of the SLK would yield. Like I said....and trapspeeds are the indicative for how fast a car is. I know you are a big believer in that, as I am![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Oh, wait: I forgot that the s/c and hardware add weight. The C&D C55k came in at 3830 pounds, about 280 over stock, so if the hardware adds the same weight to the SLK, it would bump it up to 3630 pounds. So with our 150 pound driver, it should oughta hit 119. This makes more sense! Attention to detail...
Anyway, I'd figure a potential 12.0x at 119-120, at sea level, 72 degrees farenheit, no wind, good track, yadda yadda ya..
#67
Former Vendor of MBWorld
W211 E55
I always thought the more precise way to figure out numbers for a 1/4 mile run was to make a pass down the track.
Now I know.
#68
'93 RX-7, SLK55
Guys, not sure if this helps but the wife's SLK weighs 3,400lbs (weighed it after all my little mods were done ~ 2 yrs ago). I'd forget all this flywheel Hp guesstimating as I had it dynoed at 489 rwhp/524 rwtq?
A fella with an SL65 was watching & had a cow when he saw the SLK numbers....he had just put down 505 rwhp (his SL was stock though, but at least we know the dynojet was accurate & not out of calibration). Another point to consider is not only is the SLK for 430 lbs lighter than the C55KS8, but it has a 7 spd tranny allowing it to stay in its powerband longer than AMG's std 5 Spd.
Some of you guys touched on traction & I think you are right. The car fights the ECU (with ESP turned off) a little & puts down about 3 long "morse code" twin black strips as the engine overcomes the ECU, then the ECU overcomes the engine, and vice versa. It's a little "fight" going on until about 75 mph when the morse code stops & it gets full traction. The car is wearing 265/35 Goodyear GSD3 F1s but I'm not sticking DRs on the back - it's the wife's convertible - not intended to be a drag car. See ya.
-Matt
-Matt
#70
Either one of you guys traps over 119 @ LACR Sunday Ill give you 100.00! Matter o fact anybody who tops 119 mph (except motorcycles) . gets a crispy Ben Frankiln. Hopefully I can line you up and you can help me OUT with me freaking 60 ft times !!!! My car is no match but hey maybe we go on the dial? Your car is lighter and puts down more hp! But the 63 was KING of thr drags tonight and yeah I beat at least 3 EVO's and a Lancer? Actually have no clue what that was. Anyway Mr. Evil good luck to the Audi team, you guys rock! I have an Allroad 2.7 t, LOVE IT and it has some good pop but its s t o c k. I run Mountains with it. Sorry for the semi threadjack. I cannot wait to race some of the other German super cars!!!!!!!!!!!!!!!!!![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#71
isn't that what I'm suggesting how to figure out the 0-60 times? Taking into account your 60 foot from your 1/4 mile pass, and your 1/8 mile Trapseed from that very same pass, you should be able to figure your 0-60?
#72
Quite possibly...they are only pumping 7 psi in there, and afaik rule of thumb is about 10-ish horsepower/psi. They aren't doing anything to lower the compression so that they could crank the 14 or so psi that the 55k cars are running from the factory, so I wouldn't doubt that those numbers are a teensy weensy bit optimistic. ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
If I run the numbers for it (assuming a skinny li'l 150 pound driver) with a run weight of 3500 pounds and a true 500 horsepower, it should hit 122 in the 1/4...wtf??
#73
Should be some fun runs....hope you guys are bringing video cams!! Like to see some of these things in action. Have fun, & stay safe!! ![thumbs](https://mbworld.org/forums/images/smilies/thumbsup.gif)
very interesting and good stuff! I agree.....the SC Kit definitely adds more weight to a car. Not sure the exact figure, but there is def added weight from the SC itself and the added hardware. I honestly can see an Kleeman SC SLK55 hit say 119-121 Traps in the 1/4 in ideal conditions. If so, I think it would be a very very good race. Either way....for me, it would be fun to line them up and see
I'll hopefully run the C55K soon......it should be fun to see how both cars stack up. We will have a SC E46 M3 (VF Engineering, making about 400-425 rwhp) that will be running as well.....so it should definitely be awesome to see modded S4/C55/M3's with all near each other HP figures and see how they stack up. We'll have videos as always.....stay tuned![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
#75
