CLK 55 AMG vs Altima SER 3.5 w/ Juice
BTW my clk is bone stock and had a crank sensor code when we raced.
Good kill bro
NOS is most effective off a dead stop, like a drag race.
Nice kill!
Nice kill!
Nice kill!
When you don't have the correct nitrous/fuel ratio is when things go horribly wrong rather quickly.Since basically your doubling your oxygen intake&if you don't compensate by adding fuel you will lean out&burn pistons/valves/cylinders real quick.
That's why I don't believe in all the hype with "dry shots" that rely on your cars ECU to fatten up the fuel;they're only good for 75-100hp for a reason.The only system I would trust is a wet system with designated fuel/nitrous solenoids.
Also,you will see hp across the entire rpm band,including huge mph gains up top if the vehicle is set-up properly.I've gained as much as 25mph thru the traps in the 1/4mi with spray.
I say run him at least 6x til his bottle is empty
Although I disagree with you over the fogger part, everything else you said is true. I couldnt make any sense over what the other guy was trying to say.
Although wet kits (and better yet direct port) are better than foggers, those other two kits are more expensive. If you have a small displacement car, which is well fueled and maintained by a competent mechanic, you should be able to use a 25 or 50 jet with no problems. Not to mention that single stage foggers are super CHEAP! For 500 bucks you can get 50 hp on a little tiny car!
On a side note:
Its illegal in Hawaii to have a NoS bottle hooked up in your car. You can have it installed in your car, but it cannot be connected :-) a "quick disconnect" is the way to roll around in Hawaii, legally!
IMO,a dry system is the "cheap' way out&I've learned many a valuable lesson with nitrous.I have a shelf full of burnt pistons,cylinders,toasted heads&valves in my garage.Thats why I would take the time&money to invest in a full-on wet system vs. taking a chance and eventually destroying a top end(if not the entire engine).
On the flip side,lots of kids run dry systems on their imports and some don't have any problems
But still, I've seen plenty of examples of Domestic cars running over 100 dry shots. Especially on the Chevy LS engines. Their ecu just compensates and adds the right amount. Even so, I wouldn't want to risk it and rely on the ECU. Plus from what I've read, wet shots seems to "hit harder." I had a wet 75 shot and it was truly an instant surge of lasting torque. No problems with the car either, no overheating, no top end loss. Just power. I love it and whatever cars I get in the future, I'll make sure they will always have a bottle in the trunk
Plus,with a wet system you can have it come on progressively to avoid "shocking" the tires with all the hp at once.And,multi-stage sytems are where its at
I don't think I've ever seen a multi-stage system on the streets...probably because everyone is too cheap to invest in one. You know anywhere where I can read up on one? Is it like, you have 2 50 shots and 2 buttons? 1st button gives you 50hp and when you hit the 2nd button you get another 50 equaling 100? Thanks bro.
And yeah, progressive kits sound insane. I've always been a bigger fan of having the torque build up (just like the procharger centrifugal supercharger vs maggy eaton supercharger debates going on with the American cars).
We've taken a bone stock(internally) Hayabusa that ran 9.50s and after adding a Schnitz Progressive controller were able to run mid 8's on the street w a street tire no less.My streetracing is 100% w bikes,so no cars for me but the principle is still the same.
You can set up multi stage system to deliver an initial shot of (for example)150hp,then at a pre-determined rpm have the second stage kick in,or leave the line with the 150hp on W.O.T.&then use the button to manually engage the next stage,&so forth.
Theres a fellow named Jobe Spetter that runs TurboPeople off the Saw Mill Pkway in Westchester that is a nitrous Guru&has set numerous records with (primarily,but not limited to) Buick GN's & Mustangs.He was doing multi-stage nitrous set-ups back in the late 80's&90's before it became all the rage.
Heres a few links:
http://www.holley.com/15975NOS.asp
http://www.compperformancegroupstore...y_Code=NITROUS
http://www.turbopeople.com/power.php
sorry if we hijacked the thread!
Heres a few links:
. Right now after assessing all my options on which car I should get, I keep coming back to a C6 Z06 with cams and spray...Oh yeah
sorry bro
at how ridiculous they are. Some guys were even doing wheelies down the first 1/8th mile. Awesome stuff.
