C5 Corvette vs C32 AMG
A friend and I were driving home tonight after grabbing some appetizers for happy hour. Saw a guy in a C5 'vette. He had some decently large tires on back and a V1 that I could see through the window. Not sure if he was modded, but the larger than stock tires (stock i think are 275s) had me thinking. It had the new style AZ license plate, so if it was modded, probably only had an intake (lid), but i could be wrong. I wasn't planning on doing a run, but as I passed the guy, he gave it some gas. So I matched it and we ended up doing two runs.
First run, from about 30 mph to about 80, the C5 had a slight jump and was about a fender ahead and I pulled even by 80 mph.
Then, next run, I start from the top of second. He downshifts. Again, he gets a little jump, I catch him and have a care by about 125 and then let off.
As usual, all runs were in Mexico. Calculated the DA: about 1562. The lower elevation definitely favored the V8 N/A vette.
MY'05 E55 Amg
ppl have talked about going up against z06s with the c32 all the time.
most agree the z06 can pretty easily take c32s but a c5 manual can just barely take down a c32 because its engine performs better on the top end, he prolly only had better wheels which helped get him a little more traction- but thats if the car is stock your c32 seems pretty beefy could you tell if it was a z06 or a c5?
check out this thread
https://mbworld.org/forums/kill-stor...-c5-vette.html
Nice kill! I would guess that he had more than an intake. With your trap at 13.0x you should be taking c5's no problemo. Get that LET tune and you should be able to eat c5z06's and maybe c6's.
I miss Mexico myself, car is running like crap and I have a 185mm lying around :-(. Such a waste...
It was just a C5. You can tell if it is a Z06 by the rear brake ducts:
picture http://i127.photobucket.com/albums/p...brakeduct1.jpg
i believe a stock C32 vs stock C5 will be a good race only under certain conditions.
From a dig, unless manual, I think the the C5 will have the advantage. It has 275's stock and I have seen stock C5s run 12.5s at 106-108 because of that. From a roll however, it would a closer race from low down to below 100. After 100, the LS1 motor in the C5 would probably pull away from the C32. They have great topend.
Yah, after my tune, I am considering trying out a 181 or 185....181 only because it doesnt run out on topend, like the 185 does.....sorry to hear your car isnt running well
well apparently the 185 runs lean or out of fuel up top. from what i have read, it runs out of power uptop because of this. i have not read that this was the case with the 181 anywhere. so i was wondering if a tuned 181 (which wouldnt cause any problems of running lean and out of power up top) would outrun a tuned 185 which does have power problems up top
awesome! keep us informed on the results!
