Kill Stories Discuss your exciting high speed excursions here!
True or BS?
Old 04-10-2009, 04:48 AM
User110's Avatar
2003 Cl 500
Originally Posted by jturkel
this is true and is indeed a believable story.
Even if that was the case, the poster has changed from Small 2 Seater to a SL65. I'm sure anyone who is within that area can give it a test for them selves, so long as it stays in Mexico.
ALi
Old 04-11-2009, 02:49 PM
BlownV8's Avatar
Received 1,071 Likes on 859 Posts
E55, GLS450, GL63, GLE350
The SL65 could have had a faulty intercooler pump. That might explain the look of disgust on the face of the Benz driver. It is plausable.
Old 04-12-2009, 11:41 PM
Jim Brady's Avatar
'22 G 63 AMG, '21 GLE 53 AMG, '20 NSX
Originally Posted by jmf003
Well, actually it's pretty straightforward to produce 500+ hp out of an LS1 block using "Stage 3" heads and cam plus other bolt-on parts. GM High Tech Performance upgraded an LS1 engine and achieved 550 hp--measured on a bench dyno--with this project: http://www.gmhightechperformance.com...ech/index.html.
The prices for GM performance parts are just silly cheap, too: $1799 for Stage 3 heads and $399 for a Stage 3 cam from Livernois Motorsports, for example.
FWIW....
I won't disagree with you, on the ability for the LS1 to make power and the tuners selling parts make it sound cheap and easy. The dyno'd results are not what you usually see running on the street with mufflers if it's smog legal so I factored that into my post. So we have a modified GTO beating a stock SL63.
The GTO is experienced at drag racing as he posted his times. My guess is the SL wasn't and had the ESP on which will slow the car significally when wheel spin is detected and the SL had no chance. Better driver with about the same power in a lighter car. Results believeable.
Jimmy
Old 04-13-2009, 04:12 AM
Thericker's Avatar
V12-Biturbo
Originally Posted by TMC M5
Now tell him...he is full of a big pile of steaming poopy... there is no way an SL65 would be beaten 45-120mph by a car that is not capable of trapping higher than 119mph in the 1/4 mile ...let alone beating it by the 7-8 car lengths.
Tom
Or a Tuned SL600/65 they both run 124-125 traps, he must've ran the slowest R230 AMG out right now the SL63 as others have noted, their Crank Torque is 465 @ RWTO = 380 while weighing 4300 odd lbs, this kill will easily go to the GOAT...
Quick Reply: True or BS?
