w211 E55 VS CLK550 with exhaust
Yes, please, let's have the M3 guy show up here and tell his side of the story, along with some pics of his car. And we can certainly arrange for you to run one and "draft" him.
Honestly, it was that story that made me realize just how much of a bull*****ter you are; if you had any inkling of how ridiculous that story is from pure physics, you'd understand why.
Here's why: the drag force on an automobile increases with the square of its velocity. So, if it's going 100 mph, the drag force is 100 times higher than it is at 10 mph. Down low, there wouldn't be enough of it for you to compensate for the huge horsepower difference between the two cars, and even if by some miracle you managed to keep up, as soon as you whipped out from behind him to pass, you'd instantly be out of his air pocket and hit with the full drag force, which would, given the huge horsepower difference, cause you to fall behind faster than Paris Hilton in a Calculus class (or you in a Physics class
).Similarly, there is simply no way, no how, that your car is capable of running from 5-60 with a vehicle that puts out that much more power and torque than yours, has heavier weight and larger tires, which give it more traction.
But let's make this interesting. I'm confident enough that your vehicle will not do this that I'm willing to put money on it. So how about this: we'll arrange for someone with a VBox to meet up with you, and time your 5-60 runs.
You will do ten runs.
I pay you $250 a run for each run you beat a similarly timed CLS55 or E55.
You pay me $500 for each one you lose.
Both cars to be on street tires, tires inflated to factory spec, just as were mounted on the CLK55 in the test you're citing.
That's 2:1 odds, which given you're so damn sure of yourself, you should be willing to grant in a heart beat, as it's basically $2500 free and clear to you, if you can do it.
So how 'bout it, Jon? Willing to take that bet? Given that you "know" your car WILL do it, regardless of all of the other factors that give a 209 an advantage in this department, I'd think you'll man up--for a change.
So I take it then that you're in full keyboard warrior mode again, all talk, no action.
Take the bet, Jon. Put your money where your ever-running mouth is for once. Because from where I sit, you're nothing but talk.
So for about the tenth time now, I'm challenging you to DO IT, and put some MONEY where your little TRASH-TALKING MOUTH is.
Of course, you won't do it, because as overwhelmingly proven by your past refusal to show up and run a guy who has a car that weighs the same as your car and has the same engine, let alone run a 55k car from any speed to any speed, you're nothing but a squeaky little chicken.
Oh, and blow me, I'll write what I want.
You didn't answer my question. You claim that an LSD doesn't make a car quicker at the strip, yet you also claim it help's the car's consistency at the strip. How is it possible to make a car's 1/4 mile times more consistent without improving them on average?
Regarding first part of your crap since I already answered it and it also backed up my statement. And multiple sources also had errors in them too. Btw, more consistent does not equal quickest possible. There is physics for you. There is more though...
You forgot powerband and gearing
Which hurt it if there is no issue with traction
And if it does break (both) tires loose, and requires throttle modulation and his doesn't spin whatsoever, that can change things too.
I didn't say "quickest possible", I said how is it possible for 1/4 mile ETs to be more consistent, to use YOUR term, without a net improvement?
As usual, you dodge, this time by raising yet another straw man, instead of actually asking the question that was asked.
Answer the question. How is it possible to make ETs MORE CONSISTENT without improving the average?
Also, let's examine what you wrote, in response to my asking you what "benefit" an LSD provides:
Or are you seriously dumb enough to try and argue at this point that it actually makes ETs worse?
And if it's more reliable in delivering this optimal launch/60ft, then why do you keep arguing with skratch77 that it's impossible that the LSD on the other car made the difference?
Do you really think anyone's dumb enough to believe this crap you're attempting to shovel?
Perhaps you'd care to take that bet, then. You think a CLK55 will hang with a CLS55 from 5-60 in stock form?
There is an issue with traction when you put well over 500 lb-ft down on street tires, but you obviously aren't intelligent enough to realize it.
You wrote the following, quoting a book:
The only problem is that:
1) the preceeding paragraph in the article, which you did not quote, discusses how open diffs are poor for racing because they have traction issues;
2) the portions of the two sentences you omitted hurts your case;
3) the portions you glued together to form one sentence are from two different sentences.
No matter how you slice it, that's extremely dishonest, and absolutely taken out of the context of the original article.
Now, your response was this:
And I avoided using the part because in modern nomenclature a "Spool" is essentially a locked Open Diff and is basically only used for non-handling applications such as drag racing. Btw, it doesn't transfer power back and forth. Also, you're using alledged "misquote" to illustrate a non-dragstrip benefit. That isn't the topic.
Pathetic.
As to your statement that you avoided using the part because it contains the term "spool", this too is a lie. The part you cut out of the middle of the sentence doesn't contain the word spool.
Here's the sentence as you typed it:
Without that information contained, anyone who read that and didn't catch the ellipsis you used would certainly have gotten this impression. And you, who constructed the spliced sentence, would certainly have known that when you did it.
Now, if you have another explanation, let's hear it. Why did you feel it important that anyone reading the material you cited NOT be aware of the fact that:
a) these indy drivers only use the open diffs only on long ovals,
b) they only do it on long ovals because wheelspin is not an issue on those tracks at those speeds.
How would anyone reading that quote be better served or informed by NOT having access to that very pertinant information?
Clearly, they wouldn't.
But YOU would clearly be better served by their not knowing, which was clearly your intent.
So please, stop lying about your intention here. It is as clear as glass. You lied, and you got nailed. There is simply no good reason to omit the portion of the text you omitted.
But wait, there's more: here is the section of the text in the book immediately preceeding the section that you quoted and spliced:
a) open diffs suck for racing because they have wheelspin issues;
b) however, some indy car drivers do use them for racing, but only on high speed ovals where wheelspin doesn't become a problem;
c) on other tracks, where wheelspin WILL become a problem with an open diff, drivers will either use a spool, or some other form of limited slip differential.
If we read your sentence splice we would get the impression that some indy car drivers use open diffs all the time, period.
By any measure, it is clear that your intent here was not to inform people, but to deceive them. There is simply no good reason to have omitted the portions you omitted other than to hide the fact that SOME indy car racers use open diffs, but ONLY under certain circumstances where wheelspin, the very phenomenon that LSDs are designed to eliminate, is NOT an issue, and that in ALL OTHER CIRCUMSTANCES, they DO use them.
Pathetic.
For example, my posting the following article here that you wrote elsewhere about it your considering it a "design flaw" that the new Mclaren doesn't have a limited slip differential
http://www.soakmag.com/soakworld/article.asp?c=Autos&t=Design+flaw+in+the+new+McLar en+MP4-12C%3F&aid=1154
According to the Road & Track Magazine, Nov. 2009 issue, the upcoming McLaren MP4-12C doesn't have one! This car has every ingredient to make it one of the greatest sports cars on the road except for the potential penalty of lacking an LSD. This could be a major compromise from a company that is renowned worldwide for it's engineering expertise and racing pedigree. Their best known accomplishments are multiple championships in Formula 1 and the world's fastest production car for seven years.
With an "open" differential, both wheels apply engine power to the ground and even can lay down twin black strips of rubber when there is a loss of adhesion or overpowering of the tires. However, when one becomes "unloaded" due to less traction and starts to spin, the power isn't transferred to the other wheel which means the rate of acceleration doesn't increase. This can be a problem on the street, the racetrack and the dragstrip.
Most annoyingly, daily driving can be compromised. After pulling out onto an uneven surface, begin accelerating and if aggressively programmed, the engine power could be reduced in addition to the rear brake being applied. A real pain in the ***. A little extra brake wear over time and now you're maintaining your speed or slowing down when you should be accelerating. Try it when a vehicle is headed your way and you "thought" you had enough time... That is why many drive with Traction Control partially off. I'll control my own throttle, thank you very much.
How about in rain and snow? Drive over or start on a slippery patch and you just sit and spin, the wheel with traction never getting the available power transferred. Apply more gas and you spin faster. Great. At the dragstrip it's the same thing. Get "out of the groove" with one tire and the other doesn't pick up the slack. For those that run higher traction tires such as drag radials at the dragstrip, the uneven distribution of the power from one side vs. the other can break a rear differential or half-shaft at some point.
The reason many manufacturers leave out a limited slip differential is for of cost savings, pure and simple. Less mechanical parts means less cost. If it was a size and packaging issue that meant raising the center of gravity, extending the wheelbase, or something else radical, will it mean the McLaren, while wildly fast and capable, will be left behind by the competition?
so in your opinion I should not got for the lsd?I have already spent about 2k going threw every high performance tire out there and settled to driving the car with drag radials everywhere.
My point was simply that an Open Diff is capable of a good launch but not relaibly so. My article makes the argument in favor of the LSD. I was simply pointing out the finer points and not having one isn't ALWAYS detrimental.
Question for you - if you're on DRs daily driving, are they only helpful with low air pressure AND fully warmed up?
If one reads posts #363 and #365 (just above) in this thead, one can find where I documented you doing precisely what you're now falsely accusing me of.
Provide an example of my taking any quotes in this thread out of context, please.
Yet another lie. Please substantiate this false accusation. I pointed out that you had omitted a sentence stating that indy car drivers use spool diffs on short tracks, *after* you had edited portions of two different sentences together to create a false impression of what an article actually said. I did not define what a spool differential was, nor did I discuss its operation in any way. The point is it is NOT an open differential, and that you deliberately omitted the sentence discussing its use by indy car drivers on short tracks, because that its inclusion into your quote would have torpedoed the false impression you were trying to create with your little false editing exercise.
Oh, this is rich. Not only were many of the sources I used yours, including an article that you yourself had written, but I also busted you citing a source here that you had indicated you felt was unreliable (agreeing with another poster who stated that he felt the Chrysler engineers were saying whatever they felt made the car look better while downplaying its flaws). So here you are accusing me of using wrong/incorrect sources when you blatanly sourced a quote from the dodge charger forum that you yourself had discredited in that same forum.
Further, I provided examples of your providing sources that not only didn't support your argument, they actually undercut it, and for one of them you linked it with the phrase "no reduction", when the article in question didn't even CONTAIN the word reduction, made no mention of it, and actually stated explicitly that LSDs provide superior traction at a drag strip.
So, if any source I provided is incorrect, why not try doing what you haven't done so far: prove it. Despite repeated challenges to do so, you haven't even attempted it, only chanted "it's wrong because I say it is" or "it's true because I say it is" like one of Kipling's monkeys.
Documented and proven in post #363 and others. Documented by your own words, by quoting posts you'd written on the charger forum, as well as by quoting your own article.
Yes, I have, but there's this little thing you're missing: you have to prove I'm wrong, which so far, you haven't.
Sources that were wrong or incorrect: Your first one that didn't reveal the 60fts they achieved and said you can't drift predictably with an open diff.
Another stated you only get a 1 wheel burnout with an Open Diff.
Another stated a Spool Differential is used to aid in handling.
In the real world open diff cars cut 60fts identical to what an LSD car can do all the time. See if you can answer these true/false questions. No expanding, no "yes buts". Either answer T/F or STFU.
1. An Open Diff car is capable of cutting an identical 60ft as an LSD car.
2. An Open Diff car can apply equal power to both wheels during a burnout.
3. A Spool Differential is an Open Differential design that is essentially locked, i.e. no transfering of power.
4. An LSD can negatively affect the ET by transferring power back and forth between the wheels during a pass at the dragstrip.
As to drifting with an open diff, a) they didn't state that this was applicable to all cars, only that in THIS car they couldn't initiate reliable, controllable power slides (though there are plenty of sources that will document that drifting w/open diff is much more difficult, unreliable, and uncontrollable due to only one wheel spinning reliably, and b) it's pretty well known that the top players in the sport usually use lockers, not open diffs, just as the top drag racers use lockers or LSDs (depending upon class), so that's about all that needs to be said on that point. Read more about it at driftingstreet.com, where one of the first things they recommend is to add an LSD, or even a locker.
http://www.driftingstreet.com/drift-tuning-101.html
Hate to break this to you, but that was a source that *you* originally cited; I only cited it after you linked to it to show that it didn't agree with what you were arguing:
Here's what the source you cited says:
Wow, two in a row. Firstly, this source was originally cited by you, not me, when you quoted the book contining it, and spliced the portions of two sentences together to create a doctored citation and attempt to create a false impression of what the text actually said, as I documented here. As to what it actually said, it said only that some indy car drivers use spool diffs on short oval tracks:
https://mbworld.org/forums/3874537-post363.html
Again: your source. You cited it.
Which means that, yet again, you get nailed doing exactly what you're falsely accusing me of doing, not once but twice. And it's pretty funny that in so doing, you basically undermined your own sources. Helpful hint: if you think sources are incorrect, try not citing them next time, just like you might try citing sources that actually support your argument instead of undermining it.
So that's 0/3 lame attempts. As to the Hot Rod article, which documented using physics that LSDs on solid axle cars develop more tractive force due to axle twist lowering the traction of one wheel, other than making factually incorrect claims of what the article said here, you've done nothing to discredit or undermine the article, nor to challenge the physics therein. You also incorrectly attributed the cause of rear wheel hop to axle twist, when in fact it's caused by a different phenomenon, documented here:
http://www.mc2racing.com/tech/20061012a/index.html
I don't know if you're reading a different thread from me in some bizarro universe, but in this one I've simply never claimed otherwise. Conversely, YOU claimed erroneously that a spool diff is a type of LSD, which it isn't. Judging by the question, you now seem to have discovered your error and are falsely trying to attribute it to me:
If that's the case the Challengers should be slower because they all have limited slips in them( SRT's and 6 speed R/T's). From the quater mile times posted they most certainly not. And if a lmited slip is not useful to the SRT boys, why would the Challenger have one in the first place...........(note: Chrysler made limited slip diffs standard on the SRT8 cars for 2009--improviz)
Mind you the SRT guys (the engineers quoted by Deuuuce--improviz) say that the SRT8's are optimally tuned( which they are not) have no need for catchcans( look how many of us prove that otherwise) amongst who knows what else. They seem to just find they have to justify the shortfalls of these cars no matter how ridiculous the answers are. An open diff may help your mile per hour from spinning but that in no way aids the ET. If you hook, you hook, and that's the best it can be. If not, it's all comprimise anyhow.
We all want the LSD due to the deficiencies of the open diff.
What they were talking about was the continuous torque biasing, I believe. So any detrimental effect would be rather small. Also, higher hp cars could only benefit due to traction being an issue even when rolling. Hence no open diffs in those eithers.
It would also seem that when you're writing elsewhere, you were pretty emphatic that an LSD is the way to go on street or strip, as I documented here, which really doesn't help your credibility.
And making stuff up about what I've written, falsely claiming that I was the source of citations that you yourself have made, and splicing separate sentences from an article which undermines you together to create a false impression of what the reference actually said won't help your credibility either.
