w211 E55 VS CLK550 with exhaust
#53
OK so is everything clear here ?
I mean I'm willing to race for fun if you want to see how many car lengths behind you will be. I would love to race lets say a SL65 just to see how many car lengths it will beat me I just like to race for fun. Let me know shoot me a PM.
#54
lol and to the big man, obv theres no comparison but ill still race. we can allll set it up. and remember that you called it out.
#56
PLATINUM SPONSOR
Time to Add MT ET street drag radials! Sure changed my street kill ratio..lol
__________________
![](https://mbworld.org/forums/signaturepics/sigpic87171_15.gif)
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
www.ultimatepd.com
#57
///M5 Beast
#62
///M5 Beast
Thats interesting! You should come try my stock 335i... I recently put a Mercedes Benz dealership length on one.
But in all seriouness i was in a 335i with a clk550 race and it was pretty close. 20-110mph, so im not sure if eat would be the right word for you to use? unless your modded? which then im not sure how the 550 engine responed to mods, or of course the 335i was heat soak or doesnt have the oil cooler package and such.
#63
09 CLK550
Thats interesting! You should come try my stock 335i... I recently put a Mercedes Benz dealership length on one. ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
#64
///M5 Beast
umm your race looks close enough to the one i witnessed in speed, i cant really see a stock healthy running 335i losing 4 car to 120mph to a clk550, But every race is different
#65
#73
///M5 Beast
No idea how u did that... the 135i driver was stick? had a failing Fuel pump or heat soaked really bad. he should of easily put a couple lengths on you. My 335i wasnt a slug stock trim, took out a couple 350z's, G37's, G35's and a share of other good cars. but the boost is damn low in stock trim.
Your SC pulley belt broke?
j/k
Back on topic, well kind of anyways, TrueRacerMB send E55AMGGG04 a PM, but most likely gonna have to find somewhere better then the BQE.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
#75
09 CLK550
[quote=Brisk335;3856902]No idea how u did that... the 135i driver was stick? had a failing Fuel pump or heat soaked really bad. he should of easily put a couple lengths on you. My 335i wasnt a slug stock trim, took out a couple 350z's, G37's, G35's and a share of other good cars. but the boost is damn low in stock trim.
[quote]
.... i take stock G37 by around 6-7 cars on a roll even 370z stays about 3-4 cars behind.
[quote]
