E55Kompressor vs C5 Z06
At the other extreme, a new owner of a used C5Z raced me about 5 times one time. I beat him every time from every speed by 2-3 CLs. His shifting was THAT bad.
C5 Z06 Bone-Stock Times
1--11.783 @ 116.90--1.818--J-Rod---------'02
2--11.818 @ 117.26--1.783--Ranger--------'02 11/03 Slip
3--11.844 @ 117.91--1.761--Gary2004Z06--'04 12/07 Post 229, Slip
4--11.93x @ 119.xx--1.xxx --Esoteric-------'0x
5--11.97x @ 118.80--1.90x--GMHTP--------'04 03/04
6--11.99x @ 117.61--1.xxx --02Z06Racer---'02
7--12.048 @ 115.92--1.866--pwrshfd-------'02 12/03
8--12.08x @ 115.95--1.83x--Pray ----------'02 01/06 Slip
9--12.09x @ xxx.xx --1.79x--UVETTA -------'03
10-12.131 @ 120.65--1.970--zapp109-------'04 03/09 Slip, Post #384
12.205 @ 117.96--1.91x--Nat04Z06 -----'04
12.21x @ 112.xx--1.87x--Blue Angel----'02 07/04
12.227 @ 115.09--2.011--ZR WON -----'01 04/04 Post 6
12.22x @ xxx.xx --1.77x--holedgr-------'02
12.25x @ 117.xx--1.xxx --J Z06 --------'04 05/06
12.27x @ 115.16--1.957--SpeedFreak81-'03 07/07
12.2xx @ 1xx.xx --2.xxx --My1stZ ------'03
First pass I missed 3rd and still won by pulling him top end. Second pass won by a bus+. My car had an intake which added maybe 15hp at most.
However when I first got my Z I would be trapping 114's and running embarrassing times like 13's and high 12's. A Z06 driver needs some time at the strip before he can develop a launch technique and learn to shift it properly.
An E55 could beat a C5Z no doubt, but if there was a situation where two are racing and both drivers are very experienced my money would go on the Z06.
Point being is best-to-best is how to compare two cars and if going from a roll, look at trap speeds.
) So got a twofer there with two "bone stock" vehicles. Not to say that everyone on this list is full of it as most of the traps aren't too far beyond the pale (although those 60' times are stellar for a 'vette w/that much power and that little weight), but for example a 3150 pound vette with a 175 pound driver trapping at 120.65 mph would be producing nearly 460 crank horsepower, which is nearly 60 over factory rated, and GM doesn't underrate their HP to this extent in my experience.
With 400 hp (or was it 405? I'll use that...) and 3150 pounds with a 175 pound driver, it should trap at 116 mph. Which would make it a pretty tight race against an E55 provided it had a very, very good driver who could time and execute his shifts with pert near perfect precision....of course, most drivers can't do that, which is why typically if you put an auto against a manual with relatively equal performance potential, the auto will usually come out on top, especially in standing start/low speed roll situation where any imperfections will be magnified.
Of course on the internet and in real life things like ported TB/manifold or an ECU can go unnoticed. But if you want to get into BS 1/4 times then I would start with the guys who claim their stock 55k run 11's.
And speaking of weight, the 405HP Z06 (7.69 lbs per HP) over W211 E55's (8.75 lbs per HP). A significant power to weight advantage.
The obvious answer is that it can't trap the same with a 14% power to weight disadvantage, per Physics. The amount of power to accelerate a given mass to a given speed in a given amount of time scales up or down with mass, as acceleration = force/mass per Newton. So if the 'vette and E55 both hit 116 in the 1/4, then the power to weight (or weight to power, its reciprocal; 1/x = x) ratios need to be roughly the same (they needn't be identical, as driveline losses won't be identical, etc.)
So for the E55 to have 7.69, it needs to be close to 4087/7.69, or 531 crank. How does this work out if we use a horsepower calculator?
Well, the best hp calculator I've found is one I picked up in R&T. The formula correlates very well with rated hp in most cars, within 5% and normally much closer than that, and is: hp = weight*(trap/234)^3.
So for Z06 at 3150 pounds, 150 pound driver, trapping at 116 we have hp = 3300*(116/234)^3 = 402 hp. Rated = 405.
Not bad.
And for a C32 trapping at 106 at 3700 pounds w/driver, we have 3700*(106/234)^3 = 343. Rated = 349.
Not bad. It usually works out quite well, just remember to add the weight of the driver or it'll be off.
For the E55, it comes in at 4237*(116/234)^3 = 516 crank.
Which makes more sense than 469....and with dynos hitting 420-ish on these babies, it's kind of hard to swallow 469 crank either, which would require a mere 11% driveline loss; 420 at the wheels is 512 crank with an 18% driveline loss.
Anyway, there is plenty of data showing these two cars to be very close in performance, enough to where driver is probably going to determine the outcome in most cases.
Originally Posted by Car & Driver
Propelled by the same supercharged 5.4-liter SOHC 24-valve V-8 employed in the SL55 AMG, albeit with a little less horsepower, it's even faster than the SL55 we tested last November, clocking 0 to 60 in 4.3 seconds, 0 to 100 in 9.9, 0 to 150 in 24.5, and the quarter in 12.5 seconds at 116 mph. That's quicker than anything else in this roundup—quicker, in fact, than any production sedan we've ever tested. Sports-car quick. The last Corvette Z06 we tested (December 2001) hit 60 mph in 4.0 seconds, 100 in 9.2, and 150 in 24.1, and it covered the quarter in 12.4 seconds at 116 mph.
Looks pretty close to me. So if a C5 Z06 runs a half sec. or so faster than the mags got, it's not suspicious, while if an E55 beats C&D's time by 0.3 it is? Can't have it both ways....there is certainly potential for BS on both sides of the fence, which is why I always like to go back to more scientifically conducted tests, a'la the mags, as a good baseline comparison.
With a manual car it comes down to the driver factor much more than in an automatic, so the room for error/improvement is much higher.
How exactly do the magazines test the 1/4 times? Do they just do it once? If so I would say that if that driver raced that Z06 at a track on 10 different nights his time would definatly improve considerably... from personal experience I can't say the same for auto cars.
I am suspicious myself when it comes to any 1/4 times from any forum. I go to the track once a month and it is difficult to believe that someone can trap 1.5 miles faster and .6 seconds quicker than I can (plus I have slightly stickier tires than stock). But why say to yourself that it's impossible because a magazine's time was much slower? With perfect weather and track prep + a highly experienced driver like Ranger it could very well be true.
Even if it's not, it's a good motivator to learn to race better... for me atleast.
The SL55 a bit quicker than the W211 E55 anyway so I am sure that 1/4 figure would be another .7 or more to beat.
Not bad.
The LS6 is underrated as well, so I just figured to use the factory specs for simplicity.
Do you think the magazines could be a little biased sometimes? Maybe they got paid to run a covert advertising campaign by a car company? (Not questioning the SL55 review, just curious what you think, because sometimes I am little skeptical about how they do their reviews).
And have you ever tracked your CLS55?
I mixed my tests up. I was thinking of a 12.4 test, which it did run in R&T (12.4 @ 116.4); from this, 0.41 would put you in the 11's.
But from this one, 0.051 would get you an 11.99...still, that's am amazing pick up from the mags, but these things need to be launched at idle generally speaking; if the driver in question was on a sticky track with a great DA and managed to get a 60' 0.2-0.3 lower than the mags got, he'd have more than enough pickup to gain 0.5.
No, but I did duplicate the OP's results when I ran a C5 Z06 two times in a row several months back (and against the several C6s I've run--not Z06s there, standard model
So the weight may help consistency, but there is a certain point when the lighter car should be able to cut a better 60ft. I would think this is the case with the stellar 60fts of the C5Zs on the list. Would you agree?
