CLK550 vs E92 M3
E92/90 M3's are mid 12's at least at just under 115mph trap on street tires.
http://www.dragtimes.com/BMW-M3-Timeslip-14531.html
quit kidding yourself.
DCT M3 coupes are quite fast/quick. DCT M3s should definitely beat a CLK550 especially since they're closer to stock C63 AMGs.
What. Are you saying now that your CLK550 is very close to a stock C63 AMG?
Just look at the traps. The Clk550 is I will be generous 110. Thats at least 5mph slower then a C63. Come on!
http://www.motortrend.com/roadtests/...n/viewall.html
Now motortrend has never tested the CLK550 but i can give you the time for a CLK550 driven by a normal person(not a professional)
http://www.dragtimes.com/2009-Merced...eos-22630.html
Stock for stock, a DCT M3 will smoke a CLK550.
Here's a timeslip of a M3 with similar mods to your CLK550. +6 tenths faster than your CLK550.
http://www.dragtimes.com/BMW-M3-Timeslip-17264.html
Also please post a timeslip of a CLK550 pulling anything close to a 113+ mph trap speed.
Trap speed, you see (I explain this because you seem to be very blissfully aware of what it actually is, or the ramifications thereof) is the speed at which a vehicle is traveling at the end of a 1/4 mile run. The timeslip from the perenially-trolling-and-banned badblack, (which you are well aware of, yet continue to act as his proxy in post after post, which casts doubt imo on your own honesty and credibility given that you're aware that he's been caught flat-out lying on innumerable occasions) you linked to shows a trap speed of 108.91.
That would be about 7 mph slower than the M3 timeslip linked to by e1000, which I'll post here as a courtesy since you obviously didn't bother to read it, or are just simply delusional:
Now, I don't know how Physics work in your neck of the woods, but here on Planet Earth, if vehicle "B" traps 7 mph faster than vehicle "M", then if you run vehicle "B" against vehicle "M" in any given race and both drivers can actually drive, guess which vehicle is going to pull away, fast?
Of course, this is modded vs modded (fair), but you guys always want to compare modded vs. stock (unfair). But even a stock ***DCT***, as tested by the same publication you rolled out earlier, Motor Trend, has a 4 mph faster trap than BADBLK's modded CLK550 hit (and I note that it was 60' time, not trap, that got this time; trap is where it should be, but that 60' time that is, for that vehicle, pretty dubious on street tires in a CLK550, but leaving that aside....)
[url]http://www.motortrend.com/roadtests/coupes/112_0806_2008_bmw_m3_dct_first_drive/specifications.html[]url]
0-60 4.1
0-100 9.7
Quarter mile 12.6 sec @ 113.2 mph
Hmm, 4 mph faster in a stock DCT than the modded run you posted. Gee, which is faster?
I would also point out that, in your little cherry-picking campaign, you conveniently managed not to find these nugget, of the two *stock* CLK550s listed on dragtimes:
First car: 13.256 @ 108.132
Second car: 13.280 @ 107.840
Hmm, looks like stock vs stock, M3s are pulling 4 to 7 mph faster traps than the *slowest* stock CLK550 on there (hey, if you can cherry pick, so can I), or even if you compare vs the fastest, it's a 3 to 6 mph trap speed difference.
But why stop there? Let's look at all of the stock E90/E92 M3 times/traps on dragtimes:
12.510 @ 114.810 (6 spd)
12.610 @ 113.110 (6 spd)
12.610 @ 113.020 (DCT)
12.785 @ 109.360 (not provided)
12.798 @ 114.620 (not provided)
12.910 @ 111.020 (6 spd)
12.994 @ 108.090 (DCT)
13.010 @ 110.410 (6 spd)
Average: 12.778375 @ 111.805 (also note that the two fastest were 6 speed manuals)
The average of the two stock CLK550s from dragtimes: 13.268 @ 107.986
Difference: 0.489625 seconds and 3.819 mph.
Now, of course if you come up against a lousy driver who can't launch worth a flip, you could make a respectable showing in a 1/4 run, but after that, unless he's short-shifting or bumping off the rev limiter on every shift, you're toast up high.
But that's driver error, and everyone knows that making mistakes can cost a faster car a race against a slower car. But what you seem to be arguing is that you've got the *faster* car.
But the numbers that even you provide show that this ins't the case: modded vs stock, even the slower M3 six-speed managed to post a *faster* trap in the 1/4 mile, with a 2 mph higher trap (12.8 @ 110.9), than the time posted by badblaci's *modded* car, *and* bearing in mind that a) he has been repeatedly caught lying in this forum and gets banned for inciting trollfests at least once a month, and b) on each and every occasion before he was banned where he was challenged to actually show up and repeat one of the "miracle kill stories" that he was always posting in this forum, he suddenly crawled into the woodwork and disappeared, I see no reason whatsoever to give his claims of having done the run on street tires any credence at all.
Further, the stock vs stock data plainly show that M3s are faster, by 0.489625 seconds and 3.819 mph on average for *all* models.
///M cars are built to ridiculously tight tolerances. Everything has to work perfectly, Hans better be on his game building your S85 or you could be down 20 ponies easy. I can pull fifty forum threads where peoples ///M cars broke down with low miles on them, and I can tell you from my experience I never had an issue (other than sheer age/miles causing my clutch to go at 90k miles).
All cars, despite coming from the same assembly line, are still built by people who can screw the pooch (or forget to screw the pressure plate properly). My M5 was FAST. Dyno'd at 426rwhp bone stock. It was very strong from the factory, most people don't get that lucky.
Same goes for cars that are factory freaks. Your CLK could be unusually strong, and would be consistent in its numbers due to the auto tranny doing the work. I have no doubt that you've beaten M3's on the road, that is beyond question, anything can happen in the street man and they're close enough to you in performance that it is a drivers' race.
0-60 4.1
0-100 9.7
I have a c55 lightly modded and beat a conv m3,
My friend has the sedan, stock, and I beat him by a car length at 120mph
The m gas very aggressive gearing which is a huge factor
If a m coupe raced me, I don't think it would be a walk in the park.
But as we all know, this badblack used to come into this forum, post pretty unlikely kill stories, and then disappear when challenged to show up and beat said car in person; further, he's been caught flat out lying, as a few months ago when he claimed to own a CLK55 that was in the 12's, i.e. the *last* time he got caught and banned from these forums, and in innumerable other instances.
Anyone who views someone like that as an honest broker, or tries to protray him as one without IDing him, is simply not credible in my book.
In this case, I do not think it is him considering if it was NY01 would have been banned already.
Look, personally the car hasn't been on the 1/4 so I can't give u mine. I will do it on the next private track rental I attend.
People know I'm not bull****ting about beating one
because there were people there when I beat one.
And also the one time I did lose to an e92 m3 from a 40roll I admitted it on mbworld and m3post right away that I was in the wrong gear and it was entirely my fault so he won fair and square. The guy I raced that time posted up on bimmerpost that I lost by a car and I congratulated him for it because a win is a win.
You posting 1/4 time for every m3 on dragtimes doesn't mean anything since half the people A) just send the slip and don't fill out anything else or B) are running on drag radials. There is no way to know unless you witness it in person. I have been to etown many times and everytime I have went I have yet to see a single stock e92 m3 run anything faster than a 12.8
And honestly I don't care about the track time since I drive my car on the streets everyday. I ran the M's on the empty street of mexico. So your 1/4 times don't mean anything as far as 1st, 2nd or 3rd gear pulls go. Great...the car runs 12point whatever on the track with launch control,fatter tires etc. Those factors really don't matter from a roll so the car does not have that added advantage over mine. All the m3 drivers agreed to racing from a roll. If you honestly believe that in a stock vs stock run between a car rated at 382hp and 391tq vs a car rated at 414hp and 295tq bothing weigh roughly the same from a low roll(since that is basically what happens when u run on the street)the car with 100 less tq would win then idk why I even bother wasting my time here. And if you are going to say top end the m will pull remeber that the clk is limited to 135mph. The only reason I even posted a slip is because that seems to be the only thing you care about.
Ill see if anybody I know has a vbox I can borrow, slap it on my car and record the data. We can then use my data and compare that to an M3.
In every thread ever mentioned about a clk and an m3 there has never been an instance when the clk driver said "I would take an m3 in the 1/4". All I have said is that on the street the clk550 is faster, that is,untill the road gets twisty of course.
The CLK550 IS SLOWER than the DCT M3/C63 no doubt about that. The DCT M3 is closer to the C63 AMG. My whole post basically implied that.
Yet, in this thread, as others, you trot out his 1/4 mile slip, disengenuously identify him as some "joe average" because you know damn well that if you told it was badblack we'd be more (deservedly) skeptical, etc.
And then, below, you have the stones to throw rocks at dragtimes, after YOU were the guy who first introduced it into the thread? Give me a break, dude...the same arguments you make about the M3s could just (and more likely are) as easily be applicable to your buddy badblack, particularly the drag radials in light of his very low 60' time.
Case in point: there was some E46 M3 guy who, supposedly, ran 12.x in a "stock" M3 and had it on video, but when you freeze-framed the video, you could see that: 1. the car's front passenger seat had been removed; 2. the rear wheels were not stock and differed from the front (can you say "drag radials"), and so forth...one time, nor one car, doth not a trend establish.
So yes, based upon power and actual, measured trap speeds, I do believe it, because I've seen the 0-xx times for the M3 and they're faster and I have run both cars from down low up to triple digit speeds. Furthermore, you should research power and gearing sometime and stop endlessly reciting torque as the be-all, end-all of drag races, seemingly unaware of gearing, its effects upon acceleration, and the much closer ratios of the M cars' gearing progression. I personally attended an event where a bunch of E55 and M5 guys got together, and for some reason the M5s with their much lower torque than the the E55s managed to win plenty of rolling-start races. Which would be because of gearing, and horsepower.
And the proof is in the numbers. I've seen no evidence of any CLK550, ever, trapping 110+, but there are plenty of M3s that are well beyond that.
So on aggregate, the M3 is faster. You keep spinning all you like, but numbers is numbers, and they are not on your side here.
Shoot, if you think you can hang with an M3, why not give Jon's C63 a run and get it on vid? He's said that DCTs give him a pretty good run, so you oughtta be right there with him, right? Or are you saying that you can pull a DCT, but not hang close with Jon's car somehow, given that he said the DCTs wun him pretty tight?
This ought to be good....
I mean, seriously: if someone in a car that trapped 101 or 102 was in here talking smack about he'd always pulled CLK550s, you'd be all over him like flies on stink with mag quotes, dragtimes slips, the works, but we're just supposed to take any claim as factual, no matter how far fetched, particularly when badblack is cited as a reference?
Get real. This isn't the Mercedes fanboy forum, it's the kill stories section. Having a three-pointed star on the hood doesn't get you a pass.
I can garuntee that no matter how many videos I show u guys I will hear the "The m3 driver doesn't know what he's doing" but whatever, at least I know you will feel like a douche when I prove u wrong.
by the way my car is stock unless you count the secondary cat(people also say its a resonator) and resonator delete and k&n filters modded
