New to Board - 99 ML320 air pump problem
I hope that someone here can guide me to a inexpensive solution, as money is pretty tight around here right now.
Here's what happened: Car is running fine (apparently) then one day a week ago wife exits work at 6PM to find car with battery STONE DEAD!
I went over there to help start the car. When I first put the jumper 12V onto the dead car, there was a constant whining noise under the hood - popped cover to discover the air pump was running even with the ignition off. pulled wire connector off and jump started the car replaced connector got in and it drove home fine.
I charged the battery for a day, and kept the car while wife drove my car for rest of week. I drove 6 times or so no worries.
Yesterday, wife is leaving work, as she starts car the Check Engine light comes on - car drives fine. Had a mech friend clear codes, and we discover that the 40 AMP fuse for the pump is blown! Replaced fuse, bought two more, and headed home, all okay again.
This AM, I went out and started car, put a stopwatch on the pump. It ran for about 1 min 10 sec then stopped. (supposed to be about 2 minutes from cold only, I am told). Shut down and checked fuse - it was BLOWN again!!
Here is my question - What all neeeds to be replaced, pump relay, fuse(of course) and can a fairly competent home mech do this and save a bunch of labor?? If so where is the cheapest place to buy MB partslike these, other than dealership - have had very bad luck with those guys here..
Anyway, thanks for listening to my looooong story, any of the pros out there that can advise me, I would be very grateful.
Of course money is tight. This problem wouldn't have appeared if you had plenty of cash on hand, right? There is a sensor in the seat of every Benz that measures the thickness of your wallet. When it gets thin, it forces a Check Engine Light on.
