I upgraded to bi-xenon on my ml320 1998
Old Sep 12, 2005 | 05:19 PM
Alejo123's Avatar
1998 ML-320 Debadged
Talking I upgraded to bi-xenon on my ml320 1998
but i only have high beams can somebody help me with a link
or instructions on how to fix this problem i will appreciate it thanks
Old Sep 13, 2005 | 09:14 AM
peid's Avatar
2001 ML320
I believe you need to take it to the dealer and have them programmed to recognize the Bi-Xenons.
Old Sep 13, 2005 | 10:40 AM
Mike's ML's Avatar
1990 190E 2.6, ... 1998 ML320, 2005 ML500SE
Bi-Xenon Upgrade on a 1998 ML320
The 1998 ML320 does NOT need to be reprogrammed by the dealer. However the wiring needs to be changed. Some of the pins on the headlight assembly plug must be moved and an extra ground jumper must be added. All modifications to the wiring can be made on / behind the headlight's plug. No modifications are needed to the turn signal light plug and no modifications are needed to the factory wiring. Note: the headlight assembly plug just pops out by pushing the plug to one side.
Mike
Old Sep 13, 2005 | 05:31 PM
Alejo123's Avatar
thanks to everyone i fix it by trial + error
thanks to you guys
Old Dec 16, 2010 | 07:21 PM
Cactus1's Avatar
Mercedes Ml 320 1998
Hi , I am now trying to upgrade my 1998 ML320 mercedes with a bi-xenon, and I am running into the same issue. can you send specific instructions to me? I would appreciate it.thanks, Leo
ld.clarke@comcast.net
Old Dec 17, 2010 | 04:03 AM
willpower's Avatar
1998 C280 Sport many mods, 1991 SL500 many mods, 1999 ML430 in progress, 1991 GTR (parted)
same here. Projector housings used slightly different wiring setup than pre-facelift halogens.
Take your halogens and your new projectors to a car audio shop. They're experienced with automotive wiring, and should be able to do it much easier than if you were to bring it to a mechanic (My MB mechanic recommended this too)
They should be able to look at the wiring from the original halogens and modify the wiring housing on the new projectors to match the old wiring setup.
Old Dec 17, 2010 | 07:55 PM
astropat's Avatar
CLK 320
My gf has a 2000 ML320, does this wiring solution still apply to her car or do I need to take it to the dealer?
Was thinking about getting these aftermarket headlights:
http://cgi.ebay.com/ebaymotors/6000K...item5ade031b14
They seem like they'd be plug and play since they have their own HID kit with it. Anyone have any experience doing this?
Old Dec 17, 2010 | 09:01 PM
togaduke's Avatar
2002 s 500
I got the same lights for my S430, there in my garage, came fast, look good, going to have someone put them on next week, a mobile mechanic that details cars, will let you know how it goes
Old Dec 17, 2010 | 09:08 PM
togaduke's Avatar
2002 s 500
Item Title:6000K XENON HID Mercedes Benz W220 Projector Headlights- opens in a new window or tab
Item Id:230545732022 - Price: US $230.99 Quantity:1
Old Dec 18, 2010 | 08:02 AM
willpower's Avatar
Pop out the old and pop in the new. It's not rocket science to take out the headlights. Just test your new housings in lowbeam, high beam, fogs (if applicable) and flash your hazards to test turn signals.
If all works then no problem. If not (eg: only high beams come on) compare the wiring between old and new. If different, bring to car audio shop. Dealer will just overcharge you, fudge it up, or say it can't be done at all.
