How to remove outside black window trim?
Old Oct 9, 2005 | 07:27 PM
klingon's Avatar
2009 C350 Sport, 2004 ML350
Does anyone know how to remove the outside black trim for the rear window? Its the one that surrounds the entire window including the quarter window. The stupid thing started to peel and the service dept did not install the new part properly. I'd rather do it myself if I can rather than bringing it back. My service dept - MB of Devon in PA sucks. Time to look for new dealer. Thanks.
Old Oct 11, 2005 | 10:10 AM
klingon's Avatar
Anyone??
Old Oct 12, 2005 | 10:45 AM
MBtech1's Avatar
2011 C 300 4-Matic
Do you mean the 2 strips that are hard plastic that are between the rear window and the rear-side windows? One on each side. If these are the ones you are talking about, you need to either break them off in pieces or you can make something out of some thin strong wire and 2 handles so that you can get the wire part behind the plastic so cut through the glue that holds them on. Its kinda hard to describe. As you slide the wire back and forth, it will heat up and melt the glue while enabling it to cut through it.
Old Oct 15, 2005 | 01:41 PM
klingon's Avatar
No. Its the rubber frame around the windows. See picture below.
Attached Thumbnails How to remove outside black window trim?-img_0486-12.jpg
Old Oct 16, 2005 | 10:55 AM
MBtech1's Avatar
2011 C 300 4-Matic
Actually thats the first I have seen one of those come apart so I have never had to replace one. I'll see if there is anything about it on WIS when I go to work but a lot of times its hard to find documents about exterior trim. I'll let you know if I find anything.
Old Oct 16, 2005 | 04:39 PM
redeye's Avatar
Better let the dealer do that. You are going to have to remove the fixed rear window to get to that rubber frame and reseat it.
Attached Thumbnails How to remove outside black window trim?-window1.jpg   How to remove outside black window trim?-window2.jpg
Old Oct 16, 2005 | 05:33 PM
klingon's Avatar
Thanks Redeye. You're right - this looks painful! Will be sending back to dealer next service.
Old Oct 25, 2005 | 09:59 PM
organist88's Avatar
2004 ML350, 2006 E350 4Matic, 2007 ML350
Smile
Sad...... had the same problem with my 2004 ML350.... wouldn't you think after 7 years MB would actually do something.... Btw, when my dealer washed and waxed my vehicle after servicing it (nice touch!! hehe), they got wax on the black trim... ugh.... Now how should I go about removing the wax? i tried using soap and water but it didnt do anything.... Any help would be appreciated, Thanks!
-organist88
Old Oct 26, 2005 | 11:46 PM
m500's Avatar
03 ML500
My dealer actually replace them for me under warranty. He said it shouldn't do that as my has completed faded to a different color and my car is garage all the time and hardly every park outside for more then 5 hours during shopping or buying groceries.
