Cylinder #2 Misfire?
is the ignition coil expensive?
this problem started right after I filled up the other day at a citgo(I did put 89 octane gas in).....soon as I cranked it the CEL was on and it was jumping.
Car is driveable, especially on highway....just jumps/shakes alot in park or while stopped...everytime I call the MB dealership to try and get them to schedule maintaince they always tell me they are booked up for next 2 weeks, last time I hung up on them. I talked to one of their mechanics once and he told me to just show up and not call.
I put 93 in it from time to time, generally I've always felt this was just a scam to try and get you to buy the more expensive gas and help create the high-end price point for mercedes and other luxury cars. I've never had problem with 89 in this until possibly now. I do mix it up between that and 93 though.
I did what you suggested, lucas treatement and got a half-tank to top off of 93 from shell.....noticed an immediate difference....its still misfiring though but not near as bad as it was, big difference. unless it gets worse I'm going to drive it like this till i use this tank up and put more treatment and 93 again and see if it does trick, before i go to dealer.
note: this only time I've bought CITGO gas(and only b/c of price) since I found out they are Venezuala's company, Chavez is a lunatic commie *******....we should boycott them for that alone but none the less it appears they are putting water in their gas
I filled up monday with Shell 93 V-Power, immediately it was hitting on all cylinders again but a few minutes later it started misfiring again. still not as bad as it originally was when I filled up with the bad gas at citgo.
any suggestions on cleaning this thing out?
I'm thinking now it could be the fuel fiter or something along those lines. guess i need to atleast get it diagnosed, if its the coils I'm changing them myself.
I had a simmilar misfire issue with my #8 cylinder. I red here in the forum, and learned that that wires are the weakest link.
I replaced the wires, and while at it, I replaced the plugs for that cylinder also. Easy fix.
You can diagnose the problem by switching the wires with the ones from another cylinder. Same thing with the ignition coil.
I hope this helps.
2000 ML430
78k miles
