Error Code P0500 and BAS/ESP, ETS, ABS
Old Mar 27, 2006 | 08:03 PM
VIPERS969's Avatar
2001 ML320
I got my engine light diagnosed at Autozone. It came up as P0500 (vehicle speed sensor). Where is this located and is it difficult to change?
The BAS/ESP, ETS, and ABS lights still remain on. I don't think the two are related, but they could be. What could cause all three of these lights to be on? Could it be a ABS sensor, relay, brake switch?
What do you guys think?
ML320
Old Apr 1, 2006 | 08:01 AM
gsfent's Avatar
W163 ML500 w/Kleeman headers (gone but not forgotten); R63
ML320
Check the brake light switch, known to go bad and will trip the lights you describe. Cheap part and looks easy to replace.
Regards,
Jerry
Old Apr 1, 2006 | 10:02 AM
donniebhoy's Avatar
P0500- left front/rear vehicle speed signal.
the vehicle speed signal is needed by the ECU for the actual vehicle speed . the sensor is evaluated and detected by the ESP and passes this information to the ECU via CAN as an input signal.
check the internal resistance of the VSS sensor and compare it on the right VSS sensor. if one or two sensor deviates largely then you know what to do next. approximately the resistance is about 800-2300 ohms for the front sensors and 600-1800 ohms for the rears.
it will take you just 5 minutes to remove one sensor. upon installation, cleanliness on the magnetic tip of the VSS sensor must be observed.
hope this helps.
Old Apr 1, 2006 | 10:05 AM
donniebhoy's Avatar
I don't think the two are related, but they could be. ML320
FYI: they are related via same data bus- CAN C (engine side.)
Old Apr 1, 2006 | 02:36 PM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
ML320
Easy fix, see http://forums.mbnz.org/forums/forums...66641&posts=18
Old Apr 1, 2006 | 05:03 PM
VIPERS969's Avatar
2001 ML320
hope this helps.
Where are these (VSS) sensors located?
Old Apr 1, 2006 | 06:55 PM
donniebhoy's Avatar
front sensors are mounted on the steering knuckle assemblies and the rear sensors are installed on the rear wheel carriers. remove the tires to get a clear view. the sensor only has one screw.
Old Apr 1, 2006 | 10:40 PM
VIPERS969's Avatar
2001 ML320
How much does these sensors cost?
