Low Gear Not Working?
Old Jun 21, 2006 | 11:57 AM
jorantes's Avatar
2009 C350
Ok I just purchased an '03 ML350, and followed the procedure in the owners manual to activate low gearing... when i press the button the LOW GEAR light flashes 4 times then does not stay lit... it also does not engage low gearing.... any ideas?
Old Jun 21, 2006 | 12:56 PM
AndrewAZ's Avatar
BMW FTW
Could be you have a bad motor, I have heard of a few people having bad ones. Does it make a sound at all, if it doesnt make a sound then it could be that the electrical cable from the motor came lost (I would say that is very unlikely) or the motor is just bad.
Old Jun 21, 2006 | 01:20 PM
jorantes's Avatar
2009 C350
I will look into it.. what should I be looking for to diagnose this? What are the cost of the parts, and is it a relatively easy fix???
Old Jun 22, 2006 | 04:19 AM
AndrewAZ's Avatar
BMW FTW
If you are under warranty its free. But I am guessing your out since you are asking about parts. Not sure about the cost but I wouldn't try to mess with it anymore since it seems that most of the posts the motor fails after the low gear is engaged. But the part you want to call about is the transfer case motor. I haven't heard of anyone doing a DIY on it but you would have to get under the car and I am guessing it would take some time. But if you really want you can just leave it as is broken when you trade the car in they wont check it. I have done a few off road adventures in low traction surfaces such as mud and water ext. and I have tried using low gears but find no use for them, I think you are only supposed to use them for crossing water and when the gear is engaged you lose a lot of steering ability which makes it hard to drift and do doughnuts in the mud.
Old Jun 22, 2006 | 10:38 AM
jorantes's Avatar
2009 C350
How much does the transfer case motor cost???? How do i diagnose it without paying MB dealer $94.50 p/hr for 2.5 hrs to just diagnose it...?
Old Jun 22, 2006 | 11:42 AM
jorantes's Avatar
2009 C350
Ok, I am assuming it is the TRANSFER CASE MOTOR... because it flashes the LOW GEAR LIGHT on the cluster at start up, which from what I read is an indication of a bad TRANSFER CASE MOTOR. It also flashes when I click the LOW GEAR button but never actuates into low gear... What is the cheapest place to buy this part??? I would only like OE MB parts... is there an internet site or wholesale parts dealer anywhere? THANKS!!!
Old Jun 22, 2006 | 11:43 AM
Benz_nut's Avatar
2001 ML430
$94.50 per hr? you're lucky you're not in chicago...they charge $150 and above for their labor!
Old Jun 23, 2006 | 02:46 AM
mihir_d's Avatar
2000 ML320 2006 SLK 350
Low gears are excellent when towing, especially what I do every weekend (see picture)...switch to low gear and the truck just crawls up the ramp on its own dragging the boat up with it.
Old Jun 23, 2006 | 05:56 AM
alphonsohall's Avatar
ML270CDI
I had exactly the same problem on my 2002 ML, it was a bad electric motor, i obtained a used unit.
Very easy to fit, just unplug the connector and then undo 4 bolts and it slides of a shaft....about 15 minutes at the most to do the whole job.
Old Jun 23, 2006 | 07:38 AM
azinn's Avatar
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
$136.50 + shipping here http://www.trademotion.com/partlocat...03&catalogid=1
Old Jun 23, 2006 | 10:23 AM
jorantes's Avatar
2009 C350
Thanks...! Is There Any Lights That Need To Be Reset, Codes Or Anything...? Reason Im Asking Is Bc I Can Easily Replace This Myself, But I Will Have The Dealer Do It If Any Computer Stuff Needs To Be Reset...??? Anything???
Thanks!!!
Old Jun 23, 2006 | 11:03 AM
azinn's Avatar
Thanks!!!
Having never done the job I doubt that anything needs to be reset. I would think that it would be just R & R. My 2 cents.
Old Jun 23, 2006 | 11:16 AM
ML270CDI
Thanks!!!
No dealer intervention required.......just a straight plug & play job.
Old Jun 23, 2006 | 02:36 PM
monsterinc714's Avatar
[QUOTE=alphonsohall]I had exactly the same problem on my 2002 ML, it was a bad electric motor, i obtained a used unit.
I also have the exact problem with my 02 ML.. can I ask where the electric motor is located so i can replace it?
Old Jun 23, 2006 | 03:08 PM
ML270CDI
[QUOTE=monsterinc714]
The motor is easily visible and is located on the extreme rear of the transfer case....you can see and access it without removing any underbody panels.......
Old Jun 28, 2006 | 06:29 PM
Tone's Avatar
No one has asked this but I'm assuming you are trying this with vehicle on and in NEUTRAL? If not, the light will flash four times as you describe and of course not go into 4low.
Old Jul 15, 2006 | 10:00 PM
jorantes's Avatar
2009 C350
Ok... thanks to everyones responses... I took my car to the dealer, and had them look at it, and it was determined that the computer had to be reset... not sure why... my SA really didnt tell me much, other than it had to be reset... and that it may have been from the battery getting replaced (which sounded like BS) is this a common problem??? any ideas what it was...???
WORKS PERFECT NOW...THANKS!!!
Old Jul 23, 2006 | 10:06 PM
drmiller100's Avatar
i had same problem. not only neutral, but car not moving at all, foot firmly on brake.
